I am trying to use caddy as a reverse proxy for a api and frontend usage i have in EC2 and cloudflare, so far i gave up for now on cloudflare just need to get https working for testing. But essencially i have a fastapi in python and caddy and docker composer running. I think seems right now but now i get connection refused not sure why.
{"level":"error","ts":1708450821.914592,"logger":"http.log.error","msg":"dial tcp 172.27.0.3:80: connect: connection refused","request":{"remote_ip":"172.27.0.1","remote_port":"41404","client_ip":"172.27.0.1","proto":"HTTP/2.0","method":"GET","host":"chain.e-love.app","uri":"/chain/playground","headers":{"Sec-Ch-Ua-Platform":["\"Linux\""],"Purpose":["prefetch"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"],"Sec-Purpose":["prefetch;prerender"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua":["\"Not A(Brand\";v=\"99\", \"Google Chrome\";v=\"121\", \"Chromium\";v=\"121\""],"Dnt":["1"],"Sec-Gpc":["1"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["pt-BR,pt;q=0.9,ja-JP;q=0.8,ja;q=0.7,en-US;q=0.6,en;q=0.5"],"Sec-Ch-Ua-Mobile":["?0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"chain.e-love.app"}},"duration":0.004004358,"status":502,"err_id":"4js9h2kcm","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
2.7.6 caddy-cloudflare docker file
Basically dockerfile and dockercompose
make deploy to start docker compose up build
version: '3.8'
langchain:
build:
context: .
dockerfile: Dockerfile
OPENAI_API_KEY: ${OPENAI_API_KEY}
REDIS_HOST: ${REDIS_HOST}
REDIS_PORT: 6379
REDIS_PASSWORD: ${REDIS_PASSWORD}
expose:
- 80
depends_on:
- redis
- my-network
links:
- redis
restart: always
extra_hosts:
- "host.docker.internal:host-gateway"
- my-network
build:
context: ./caddy
dockerfile: ./Dockerfile
- 443:443
- ./data/caddy_data:/data
- ./data/caddy_config:/config
depends_on:
- langchain
PROXY_BACKEND: langchain
PROXY_PORT: ${PROXY_PORT}
DOMAIN: ${DOMAIN}
CF_API_TOKEN: ${CF_API_TOKEN}
redis:
image: redis
restart: always
command: redis-server --requirepass ${REDIS_PASSWORD}
- my-network
- ./data/redis:/data
caddy_data:
caddy_config:
redis:
driver: local
my-network:
driver: bridge
{$DOMAIN} {
reverse_proxy http://{$PROXY_BACKEND}:${PROXY_PORT}
FROM iarekylew00t/caddy-cloudflare:latest
RUN mkdir /app
COPY start.sh /app/start.sh
CMD ["sh", "/app/start.sh"]
My api docker
# Use an official Python runtime as the base image
FROM python:3.12.1
# Set the working directory in the container
WORKDIR /app
# Copy the requirements file to the working directory
COPY requirements.txt .
RUN true
# Install dependencies
RUN pip install -r requirements.txt
RUN true
# Copy requirements
RUN true
# Copy app code
COPY app/ .
RUN true
COPY female.txt .
RUN true
# Export necessary port
EXPOSE 8000
ENV OPENAI_API_KEY=${OPENAI_API_KEY}
ENV REDIS_HOST=${REDIS_HOST}
# Define the command to run on container start
CMD [ "python", "server.py" ]
