): 2.0.0
I use Docker (docker-compose
) to run Caddyserver. Here is the command of my caddy service: command: ["caddy", "run", "--config", "/etc/caddy/Caddyfile"]
Docker version 19.03.1
docker-compose version 1.22.0
docker-compose -f docker-compose.caddy.yml up -d --build
version: "3.4"
# other services...
image: caddy:2.0.0
restart: always
deploy:
replicas: 2
update_config:
delay: 10s
restart_policy:
condition: on-failure
- www:/var/www/html
- caddy_data:/data
- caddy_config:/config
db-data:
conf:
www:
cert:
caddy_data:
caddy_config:
:443 {
root * /var/www/html/{host}
on_demand
reverse_proxy /sites/action/* api:4000
I run a platform where users can host their websites, so I have plenty of domains hosted into the server, each domain has its own directory. Whenever visitors hit into a domain I look into the parent directory by the {host}
parameter and serve its files. It works totally fine until I want to redirect non-www to www or www to non-www. This is not my problem as well, the problem arises when I don’t know whether the domain should redirect to www or non-www!
When the domains are created by the users some of them may choose to forward to www and some of them may choose to forward to non-www. I can create a system file depending on that choice (eg: redirect-rules.conf
). I need a way to read the content of that file and execute it in Caddyfile
Let’s say a domain directory example.com
was created and chosen www
to be forwarded into example.com
. I am thinking of a pseudo redirect-rules.conf
file that contains:
redir www.example.com example.com
I tried to read a conf file using import
directive like this: import /var/www/html/{host}/redir_rules
. But this configuration is wrong because I am not allowed to use variable into a file path!
The error I get: Error during parsing: File to import not found: /var/www/html/{host}/redir
What would be the ideal solution for this scenario?
import a conf file from root
, seems like it import directive reads file from absolute path.
