Dynamic Domain Routing with Caddy - Challenges with Multi-Tenant SaaS Proxy Configuration
I’m developing a SaaS platform where customers can add their own custom domains with a unique architecture:
Infrastructure Overview:
  • Caddy v2 (latest version)
  • Docker-based deployment
  • Frontend running on port 5173
  • Centralized proxy mechanism
Domain Configuration Flow:
  1. Customer adds a custom domain (e.g., pay.customercompany.com)
  2. Domain points to a central proxy (proxy.myplatform.com.br)
  3. Central proxy (proxy.myplatform.com.br) has a gray cloud Cloudflare configuration, pointing directly to the server IP
DNS Configuration:
pay.customercompany.com.br (CNAME) → proxy.myplatform.com.br
proxy.myplatform.com.br (A Record) → Server IP
Current Caddy Routes Configuration:
    "match": [
        "host": ["proxy.myplatform.com.br"]
    "handle": [{
      "handler": "reverse_proxy",
      "upstreams": [
          "dial": "frontend:5173"
    "match": [
        "host": ["api.myplatform.com.br"]
    "handle": [{
      "upstreams": [
          "dial": "backend:3000"
    "match": [
        "host": ["pay.customercompany.com.br"]
    "handle": [{
      "upstreams": [
TLS Configuration:
  "tls": {
    "automation": {
      "policies": [{
        "subjects": ["*"],
        "issuers": [{
          "module": "acme",
          "challenges": {
            "http": { "disable": false },
            "tlsalpn": { "disable": false }
Solutions Already Attempted:
  1. Wildcard TLS configuration (*)
  2. Adding Cloudflare-specific headers
  3. Verifying DNS resolution
  4. Manually configuring routes
  5. Validating internal container connectivity
Current Challenge: When trying to access a dynamically added domain (e.g., pay.customercompany.com.br), I encounter:
  • Browser Error: “Too Many Redirects” (ERR_TOO_MANY_REDIRECTS)
  • Domain has a valid SSL certificate
  • Cloudflare configured with gray cloud
Technical Environment:
  • Ubuntu Server
  • Docker
  • Containers:
    • Caddy (reverse proxy)
    • Frontend (React)
    • Backend (Node.js)
Specific Questions:
  • Why aren’t dynamically added domains being routed correctly?
  • How to handle multiple domains in a dynamic environment?
  • Are there specific Cloudflare configurations needed for Caddy?
Additional Information:
  • Latest Caddy version
  • Domains point correctly
  • SSL certificates functioning
Looking for guidance on implementing a robust, dynamic domain routing solution that can:
  • Dynamically add new customer domains
  • Correctly route through the proxy domain
  • Automatically manage SSL certificates
  • Support multiple customer domains
Any insights or solutions would be greatly appreciated!
I can elaborate later, but your use case is definitely supported and where Caddy excels. You need to use the on-demand TLS feature. I’ve linked the relevant sections in the docs and in a Wiki article:
