Duplicating http traffic with reverse_proxy
1. Caddy version:
v2.6.2 linux amd
tar, and using install.sh
linux, systemd
Hi,
piggy backing on this previous closed thread: How to duplicate traffic using http proxy
was there ever an issue created? or a PR which was merged for this? my needs are identical to these post
Thank you!
You can use GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy with the tee handler to pipe traffic to multiple other handlers.
But this is a TCP/UDP layer proxy, and only supports JSON config (no Caddyfile), so it’s a bit more work to set up.
I’ve decided to use GoReplay to produce my desired outcome instead, but thank you for your help!!
