Doubts about how to implement 103 Early Hints
Hi, first of all thank you for the amazing work on the Caddy server, I have just started using it recently and I’m loving it.
I’m trying to add Early Hints to the new site I’m building, I’m using vite and react-router v7 and I have a script that checks the manifest generated by vite for each route and adds the Link header with the assets I’d like to fetch with the 103 Early Hints. I have tried adding the respond 103 to my Caddyfile pretty much everywhere, and I also tried moving the script from my entry.server.jsx directly to a early-hints.caddy file that I was then importing inside my Caddyfile but nothing seemed to work.
The documentation doesn’t provide enough information on how to set this up so I don’t even know what I’m doing wrong here, some guidance would be very appreciated.
There’s no error messages, I just can’t seem to get the 103 requests to work.
caddy --version
I have installed Caddy via xcaddy (v0.4.5_linux_amd64) with the following command:
xcaddy build --with github.com/darkweak/souin/plugins/caddy --with github.com/ueffel/caddy-brotli --with github.com/darkweak/storages/redis/caddy
Ubuntu 24.04.3 LTS (GNU/Linux 6.8.0-87-generic x86_64)
Running two Docker containers inside, one for WordPress and the other for the React app.
caddy start --config /etc/caddy/Caddyfile
# Global options
	# Email for Let's Encrypt
	email dev.team@carney.co
	# Souin Cache Configuration
	order cache before rewrite
	cache {
		# Cache storage backend - Redis for production
		redis {
			url localhost:6379
		ttl 1h
		stale 1h
		# Cache key configuration
		key {
			disable_body
			disable_host
			disable_method
		log_level INFO
		allowed_http_verbs GET HEAD
		# Cache management API
		api {
			basepath /api/cache
			souin
# WordPress Admin Server (wpadmin.carney.co)
wpadmin.carney.co {
	# Increase upload size limit
	request_body {
		max_size 5120MB
	# Redirect root to /wp-admin
	@root path /
	redir @root /wp-admin 301
	# Proxy all requests to WordPress
	reverse_proxy localhost:8080
# Main Site (beta.carney.co)
beta.carney.co {
	# Enable compression
	encode br gzip
	respond 103
	# Static assets - serve from local filesystem
	@static_assets {
		path_regexp static ^/(assets|lottie)/.*\.(js|css|json)$
	handle @static_assets {
		root * /var/www/static-assets
		# Add caching headers
		header Cache-Control "public, max-age=31536000"
		header Vary "Accept-Encoding"
		respond 103
		file_server {
			precompressed br gzip
	# Daily carnage routes - new posts daily
	handle /daily-carnage* {
		# Cache for 24 hours (refreshes daily with new content)
		cache {
			ttl 24h
			stale 48h # Serve stale for 48h if backend is down
		respond 103
		reverse_proxy localhost:3060
	# Cache eviction endpoint for Apollo
	handle /api/cache/evict {
		# Aggressive caching since content rarely changes
		cache {
			ttl 7d # Cache for 7 days (pages almost never change)
			stale 14d # Serve stale for up to 14 days if backend is down
			# Respect cache headers from upstream
			# If Remix sets Cache-Control: no-cache, it won't be cached
			# Use /api/cache/evict during deployments to clear cache
		respond 103
Remove respond from your config. There’s nothing special to do if your upstream app has 103 support already, reverse_proxy will handle it.
The respond directive is for when you want to manually write a response back to the client, you wouldn’t ever use it at the same time as reverse_proxy.
Does your app write a 103 response with Link headers before its main response? It needs to do that.
This makes sense, at the moment I’m serving my application through React Router and they don’t have it implemented yet. I’m going to write a proposal for it on their repo. Thanks!
You can match the request and set hints and/or push from Caddy independent of upstream if you want. I use the following with a mediawiki site:
@hint {
	protocol http/2+
	query title=*
	path /mediawiki/index.php*
	path /w/*
route {
    header @cache {
		Cache-Control "max-age=31536000, s-maxage=31536000, public"
		Strict-Transport-Security "max-age=31968000;  preload"
		X-Frame-Options DENY
	route @hint {
		header Strict-Transport-Security "max-age=31968000;  preload"
		header X-Frame-Options DENY
		header +Link "</mediawiki/load.php?lang=en-gb&modules=ext.visualEditor.desktopArticleTarget.noscript%7Cskins.timeless&only=styles&skin=timeless>; rel=preload; as=style"
		header +Link "</mediawiki/load.php?lang=en-gb&modules=site.styles&only=styles&skin=timeless>; rel=preload; as=style"
		header +Link "</mediawiki/load.php?lang=en-gb&modules=startup&only=scripts&raw=1&skin=timeless>; rel=preload; as=script"
		respond 103
		push
root * /var/www/domains/mydom.com/htdocs
php_fastcgi unix//var/run/php-fpm/fpm-wiki.socket
file_server {
	precompressed br zstd gzip
