As I mentioned endpoints are working. But I’m getting some response errors. r.
So do I need any header_down entries? My router firewall lets any port outbound through. Do those responses have to travel back to that first caddy instance at AWS lightsail? or do they get routed to the IP shown directily. If former then maybe I have to open up a bunch of ports at lightsail instance which would be maybe bad. Just a bit clueless how responses are handled that might involve web socket ports (which is what I assume those are?)
at my router
Feb 02 08:37:50 router caddy[12230]: {"level":"error","ts":1643819870.2433317,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 10.0.0.1:443->106.11.158.35:27240: write: broken pipe"}
Feb 02 08:47:39 router caddy[12230]: {"level":"error","ts":1643820459.2609708,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 10.0.0.1:443->114.119.145.66:59730: write: broken pipe"}
Feb 02 08:55:26 router caddy[12230]: {"level":"error","ts":1643820926.2230718,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 08:55:29 router caddy[12230]: {"level":"error","ts":1643820929.5755541,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 09:00:07 router caddy[12230]: {"level":"error","ts":1643821207.2664323,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 10.0.0.1:443->185.191.171.20:8192: write: broken pipe"}
Feb 02 09:02:39 router caddy[12230]: {"level":"error","ts":1643821359.936474,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 10.0.0.1:443->106.11.156.76:17515: write: broken pipe"}
Feb 02 09:22:46 router caddy[12230]: {"level":"error","ts":1643822566.8292458,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 09:44:41 router caddy[12230]: {"level":"error","ts":1643823881.5220153,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 09:45:06 router caddy[12230]: {"level":"error","ts":1643823906.6379797,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
at the first instance at AWS lightsail
Feb 02 16:27:17 awsgpcca caddy[27467]: {"level":"error","ts":1643819237.6308122,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:31:03 awsgpcca caddy[27467]: {"level":"error","ts":1643819463.8976974,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:31:51 awsgpcca caddy[27467]: {"level":"error","ts":1643819511.1487591,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:32:05 awsgpcca caddy[27467]: {"level":"error","ts":1643819525.2367232,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:32:12 awsgpcca caddy[27467]: {"level":"error","ts":1643819532.967717,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:55:26 awsgpcca caddy[27467]: {"level":"error","ts":1643820926.2085109,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 16:55:29 awsgpcca caddy[27467]: {"level":"error","ts":1643820929.5608206,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 17:22:46 awsgpcca caddy[27467]: {"level":"error","ts":1643822566.8140965,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 17:44:41 awsgpcca caddy[27467]: {"level":"error","ts":1643823881.5066693,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Feb 02 17:45:06 awsgpcca caddy[27467]: {"level":"error","ts":1643823906.6216168,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
