There’s no reason it shouldn’t, assuming you’re connecting to https://54353.test.ourdomain.com and the DNS for 54353.test.ourdomain.com resolves to your Caddy server correctly.
What error are you seeing instead of a working webpage?
OK I’m getting this error: 2017/09/12 16:09:37 [log] failed to get certificate: acme: Error 400 - urn:acme:error:malformed - Error creating new authz :: DNS name does not have enough labels
OK I think I understand the problem. I didn’t got anything in the log and it’s look like something that not sure related to Caddy (but maybe it is).
I have my own SSL on this server but I didn’t set him up in the Caddyfile and I just use :433
When I try to enter any domain on the server it’s working great but only when I try to enter to this domain the I had a custom SSL in the past it’s getting the first error I sent (By chrome):
This site can’t provide a secure connection
54353.test.ourdomain.com sent an invalid response.
Try running Network Diagnostics.
ERR_SSL_PROTOCOL_ERROR
Does thats sound like something you know?
And thanks again for all the help you give here! the product is amazing!
Maybe try curling the site to avoid any kind of browser-related history/cache issues? If your previous SSL setup is truly out of the way now, curl will give you an accurate response.
curl: (35) Unknown SSL protocol error in connection to 1.test55.example.me:-9838
He just can’t confirm the SSL.
And this is for example Firefox error:
An error occurred during a connection to 1.test55.example.me. Peer reports it experienced an internal error. Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
I’m happy to volunteer a bit of time to have a peek. I probably won’t need SSH, but if you want to send me some more details - the IPv4 address, and the publicly addressable domain you’re using - I might be able to give some advice as a fellow Caddy user.
Just keep in mind I’m not affiliated with Caddy or Light Code Labs, I’m just a friendly face on the forums here.
