Does {uri} equals {path}?{query}?
I can not submit code , so I use img, because:
the problem:
I convert ngnix config to caddy ,my nginx config:
my caddyFile :
but when it does not work, the jscode params not append to the query, when I change:
it worked, I don’t know why?
like 1
win10
caddy start
none
none
none
You just want to add a jscode param to the query?
rewrite * ?{query}&jscode=asdf
{uri}&… Won’t work right if there is no query string in the URI.
thanks, I test some case:
  • if exist ?, before ? can rewrite path, after ? can rewrite query, if before ? is empty, then path will not change, but if after ? is empty, then rewrite query to empty. example http://example.com/abc/?def=3 :
    rewrite rule:  ?cd=2
    get : http://example.com/abc/?cd=2 (path not change, only change query)
    rewrite rule:  ?
    get : http://example.com/abc (path not change, query is empty)
    rewrite rule:  /mn?cd=2
    get : http://example.com/mn?cd=2 (path and query change)
  • if not exist ?, default is rewrite path, and query will not change, example http://example.com/abc/?def=3 :
    rewrite rule:  /mn
    get : http://example.com/mn/?def=3 (path change, query not change)
  • if use {path} or {query}, and append some params before or after their, it worked , but if use {uri}, only before {url} part can work , after {url} part will ignore, so my &jscode=asdf is not work. example http://example.com/abc/?def=3 :
    rewrite rule:  /mn{path}/op
    get : http://example.com/mn/abc/op?def=3 (path before and after change)
    rewrite rule:  ?mn/{query}/op
    get : http://example.com/abc/?mn/def=3/op (query before and after change)
    rewrite rule:  mn/{uri}/op
    get : http://example.com/mn/abc/?def=3 (uri only before part change)
