Does tls_insecure_skip_verify only skip verification from Caddy to localhost?
Does tls_insecure_skip_verify when setting up reverse_proxy only disable verification from Caddy to the internal app? Or does it disable it public facing as well?
Thanks!
Ben
EDIT: Nvm, found my answer, it only applies between the reverse proxy and the backend.
Correct, only the connection to the backend/upstream.
Remember though, using this, you’re turning off all security. The connection could be trivially man-in-the-middle’d. The encryption is meaningless without verification, it only adds latency overhead. Might as well just use HTTP, it would be more performant.
