Does caddy need port 80 open for renewals
hi all,
for letsencrypt you need both port 80 and port 443 open (port 80 for the challenge/renewal) is this the same for caddy ?
thanks,
rob
It depends on which challenge you want to use to get a certificate. With Caddy, you can choose from:
