1. Output of caddy version
container on debian 11.5 amd64
debian 11.5 amd64
docker
host network
docker run --rm -it --net=host -v $PWD/Caddyfile:/etc/caddy/Caddyfile -v $PWD/config:/config -v $PWD/data:/data chain710/caddy:v2.6.2-1
chain710/caddy:v2.6.2-1 is built with plugins:
github.com/mastercactapus/caddy2-proxyprotocol
github.com/mholt/caddy-l4
no compose file
admin off
email me@example.com
skip_install_trust
servers :9443 {
listener_wrappers {
proxy_protocol {
timeout 2s
allow 192.168.1.1/16
tls
localhost {
respond "hello, world"
example.com:9443 {
output stderr
reverse_proxy http://localhost:3000 {
trusted_proxies private_ranges
example.com:9443
serve behind another proxy(frp), which expose 443 port
Visit http://example.com
redirect to https://example.com:9443/
curl -i http://example.com
HTTP/1.1 308 Permanent Redirect
Content-Length: 0
Server: Caddy
The reason I can not use 443 on example.com
is:
I prefer localhost use 443 port
while example.com
with proxy_protocol must listen another port
This problem can be solved in nginx with option
port_in_redirect off;
I wonder if there is similar option in caddy?
No log needed.
Nothing
http://nginx.org/en/docs/http/ngx_http_core_module.html#port_in_redirect
