2.4.6
Ubuntu. Systemd
Sendy web app
Paste command here.
root * /var/www/sendy
tls foo@example.org
output file /var/log/caddy/sendy.access.log {
roll_size 3MiB
roll_keep 5
roll_keep_for 48h
format console
php_fastcgi unix//run/php/php7.0-fpm.sock {
split .php
index index.php
try_files {path} {path}.php
#@catch {
# path_regexp ^/([a-zA-Z0-9-]+)$
#rewrite @catch {path}.php
@w path_regexp w ^/w/([a-zA-Z0-9/]+)$
rewrite @w w.php?i={re.w.1}
@l path_regexp l ^/l/([a-zA-Z0-9/]+)$
rewrite @l l.php?i={re.l.1}
@t path_regexp t ^/t/([a-zA-Z0-9/]+)$
rewrite @t t.php?i={re.t.q}
@unsub path_regexp unsub ^/unsubscribe/(.*)$
rewrite @unsub unsubscribe.php?i={re.unsub.q}
@sub path_regexp sub ^/subscribe/(.*)$
rewrite @sub subscribe.php?i={req.sub.q}
3. The problem Iām having:
I am running Sendy web app from Caddy. I am seeing a redirect that I am unable to find the cause of.
Request https://example.org/\evil.com/%2F.. gives 308 redirect to evil.com. I cannot see that Sendy is doing a 308 redirect. Is my Caddy config causing a 308 redirect?
I am trying to fix this redirect so a user will not be redirected out of my domain.
Finding 308 redirect in Sendy source files.
