So, I tried to install the required module (which is Route53). I can see it when I execute caddy list-modules. And now, it returns below error:
2024/02/09 09:01:41.676 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
2024/02/09 09:01:41.680 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "/etc/caddy/Caddyfile", "line": 146}
2024/02/09 09:01:41.681 INFO admin admin endpoint started {"address": "0.0.0.0:2020", "enforce_origin": false, "origins": ["//0.0.0.0:2020"]}
2024/02/09 09:01:41.681 WARN admin admin endpoint on open interface; host checking disabled {"address": "0.0.0.0:2020"}
2024/02/09 09:01:41.683 INFO caddy.storage.redis Provision Redis simple storage using address [ZZZ.ZZZ.ZZZ.ZZZ:6379]
2024/02/09 09:01:41.683 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0003b8b00"}
2024/02/09 09:01:41.683 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/02/09 09:01:41.683 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/02/09 09:01:41.684 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/02/09 09:01:41.685 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/02/09 09:01:41.685 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/02/09 09:01:41.685 INFO http enabling automatic TLS certificate management {"domains": ["*.domain.id"]}
2024/02/09 09:01:41.685 WARN tls storage cleaning happened too recently; skipping for now {"storage": "{\"client_type\":\"simple\",\"address\":[\"ZZZ.ZZZ.ZZZ.ZZZ:6379\"],\"host\":[],\"port\":[],\"db\":0,\"timeout\":\"5\",\"username\":\"\",\"password\":\"REDACTED\",\"master_name\":\"\",\"key_prefix\":\"caddy\",\"encryption_key\":\"\",\"compression\":false,\"tls_enabled\":false,\"tls_insecure\":true,\"tls_server_certs_pem\":\"\",\"tls_server_certs_path\":\"\",\"route_by_latency\":false,\"route_randomly\":false}", "instance": "df8a8ade-1145-402b-b190-dddb6f4d03b2", "try_again": "2024/02/10 09:01:41.685", "try_again_in": 86399.99999953}
2024/02/09 09:01:41.686 INFO tls finished cleaning storage units
2024/02/09 09:01:41.688 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2024/02/09 09:01:41.688 INFO serving initial configuration
2024/02/09 09:01:41.691 INFO tls.obtain acquiring lock {"identifier": "*.domain.id"}
2024/02/09 09:01:44.696 INFO tls.obtain lock acquired {"identifier": "*.domain.id"}
2024/02/09 09:01:44.696 INFO tls.obtain obtaining certificate {"identifier": "*.domain.id"}
2024/02/09 09:01:44.699 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["*.domain.id"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/02/09 09:01:44.699 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["*.domain.id"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/02/09 09:01:46.132 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "*.domain.id", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2024/02/09 09:01:48.227 ERROR tls.issuance.acme.acme_client cleaning up solver {"identifier": "*.domain.id", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.domain.id\" (usually OK if presenting also failed)"}
2024/02/09 09:01:48.483 ERROR tls.obtain could not get certificate from issuer {"identifier": "*.domain.id", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[*.domain.id] solving challenges: presenting for challenge: adding temporary record for zone \"domain.id.\": operation error Route 53: ChangeResourceRecordSets, https response error StatusCode: 400, RequestID: dff13b3a-d8a0-4b64-ab1b-24c380744aff, InvalidChangeBatch: [RRSet with DNS name _acme-challenge.domain.id., type TXT cannot be created as other RRSets exist with the same name and type.] (order=https://acme-v02.api.letsencrypt.org/acme/order/1561474067/243071084437) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2024/02/09 09:01:48.486 INFO tls.issuance.zerossl waiting on internal rate limiter {"identifiers": ["*.domain.id"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2024/02/09 09:01:48.486 INFO tls.issuance.zerossl done waiting on internal rate limiter {"identifiers": ["*.domain.id"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
We do have _acme-challenge in Route53, we use it for email purposes. The type is Multivalue answer. Is there any way for caddy to be able to append the new value to the record?
P.S. For the record, I already created the required user and its policy as well.
