Docker xcaddy with custom plugins
Hello!
I’m trying to build a custom Caddy as a docker container but I run in to the following issue:
[+] Building 0.2s (2/2) FINISHED
 => [internal] load local bake definitions        0.0s
 => => reading from stdin 561B        0.0s
 => [internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 386B        0.0s
Dockerfile:7
   5 |         xcaddy build \
   6 |          --with github.com/mholt/caddy-l4
   7 | >>>      --with github.com/hslatman/caddy-crowdsec-bouncer
   8 |          --with github.com/caddy-dns/desec
   9 |
failed to solve: dockerfile parse error on line 7: unknown instruction: --with
I use the example from the instructions
FROM caddy:builder-alpine AS builder
RUN --mount=type=cache,target=/go/pkg/mod --mount=type=cache,target=/root/.cache/go-build xcaddy build --with github.com/mholt/caddy-l4--with github.com/hslatman/caddy-crowdsec-bouncer--with github.com/caddy-dns/desec
FROM caddy:alpine
What am I doing wrong?
You are missing the backslash on the —with argument, docker otherwise does not know what belongs to the previous command line.
