Docker Use a custom certificate and key
Hi. I have written and deleted multiple versions of this question because it gets very convoluted to ask a very simple question.
I can run caddy locally and use a custom certificate and key:
tls cert.pem key.pem
When I bind these to a docker container using a Caddyfile, the logs say the certificates are loaded, but I can not connect.
Is there a way to use custom certificate and key with the latest official image?
Caddyfile local
foo.test
reverse_proxy localhost:8080
tls ./certs/foo.test.pem ./certs/foo.test-key.pem
Caddyfile in docker
foo.test {
	reverse_proxy / web:8080
	tls /root/certs/foo.test.pem /root/certs/foo.test-key.pem
DockerCompose
    image: "arm64v8/caddy"
      - ./certs:/root/certs # to sync mkcert certificates to Caddy
      - ./Caddyfile:/etc/caddy/Caddyfile  # to mount custom Caddyfile
      - "443:2019"
    depends_on:
      - web
  web:
    build: ./app
Log
 [+] Running 3/0
 ✔ Network caddy_default    Created                                                     0.0s
 ✔ Container caddy-web-1    Created                                                     0.0s
 ✔ Container caddy-caddy-1  Created                                                     0.0s
Attaching to caddy-caddy-1, caddy-web-1
caddy-caddy-1  | {"level":"info","ts":1690036332.68093,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy-caddy-1  | {"level":"info","ts":1690036332.6823535,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy-caddy-1  | {"level":"info","ts":1690036332.6827698,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40003aed90"}
caddy-caddy-1  | {"level":"warn","ts":1690036332.6866915,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [foo.test]: no OCSP server specified in certificate"}
caddy-caddy-1  | {"level":"info","ts":1690036332.6867504,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"foo.test","server_name":"srv0"}
caddy-caddy-1  | {"level":"info","ts":1690036332.686761,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy-caddy-1  | {"level":"info","ts":1690036332.687039,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy-caddy-1  | {"level":"info","ts":1690036332.687104,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
caddy-caddy-1  | {"level":"info","ts":1690036332.687187,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy-caddy-1  | {"level":"info","ts":1690036332.687213,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy-caddy-1  | {"level":"info","ts":1690036332.6873643,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy-caddy-1  | {"level":"info","ts":1690036332.68738,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy-caddy-1  | {"level":"info","ts":1690036332.6873841,"msg":"serving initial configuration"}
caddy-caddy-1  | {"level":"info","ts":1690036332.687398,"logger":"tls","msg":"finished cleaning storage units"}
This is wrong. Caddy is listening on port 443 inside the container.
Port 2019 is for the admin endpoint, which you should not expose publicly.
Thank you. That solved it.
The codewithhugo article using the abiosoft image had ports: 443:2015 which worked. So I thought we had to listen on 443 and forward it to the container on 2019 in the v2 image.
Just didn’t understand what was happening. Ugh,
Since I couldn’t find a simple example, here is how to use your own pem files generated with mkcrt., e.g.
Edit /etc/hosts 127.0.0.1 foo.test
docker compose up
curl https://foo.test
Hello world
docker-compose.yml
    depends_on:
      - web
  web:
    build: ./app
caddy file
foo.test {
app Dockerfile
FROM node:10
WORKDIR /node/app
COPY ./index.js /node/app
ENV NODE_ENV production
ENV PORT 8080
EXPOSE 8080
CMD ["node", "index.js"]
app index.js
const http = require('http')
const server = http.createServer((req, res) => {
  res.writeHead(200, { 'Content-Type': 'text/plain' });
  res.end('Hello world');
server.listen(process.env.PORT)
