Docker usage and cert issuing
Hi all, i’m using a Caddy as a container, and lately i start encountering errors with duplicate certificate rates exceeded.
{"level":"error","ts":1727331999.2136056,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"domain","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - too many certificates (5) already issued for this exact set of domains in the last 168h0m0s, retry after 2024-09-26 16:14:04 UTC: see https://letsencrypt.org/docs/duplicate-certificate-limit/"}
I’m running caddy as a docker image caddy:2.7.6
Caddy run in docker compose
Docker
    image: caddy:2.7.6
    env_file:
      - .env
      - ./docker/caddy/Caddyfile:/etc/caddy/Caddyfile
    depends_on:
      - api
{$API_DOMAIN} {
	reverse_proxy api:8000
When i do docker compose build (to rebuild images of other services caddy is not rebuilded because it’s the same image) and docker compose up, caddy triggers cert renewal for some reasons
See Keep Caddy Running — Caddy Documentation. You must have a volume for /data, otherwise every time you recreate the container you throw away your certificates, so they need to get reissued, meaning you hit rate limits.
Now that you’ve hit rate limits, you’re stuck and you’ll need to wait until they’re cleared, or use a different domain.
Please use the latest version, v2.8.4
Many thanks for help, it solved the issue for me
