Docker registry behind caddy as reverse proxy
Hey, I’m running a docker registry inside a docker container behind caddy.
Pushing and pulling works just fine, but building with drone fails because of some authentication stuff.
172.17.0.21 - [19/Jul/2016:22:10:11 +0000] "GET /v2/ HTTP/1.1" 401 17
172.17.0.21 - [19/Jul/2016:22:10:11 +0000] "GET /v1/_ping HTTP/1.1" 401 17
172.17.0.21 - [19/Jul/2016:22:10:11 +0000] "POST /v1/users/ HTTP/1.1" 401 17
172.17.0.21 - [19/Jul/2016:22:10:11 +0000] "GET /v1/users/ HTTP/1.1" 404 14
Now there’s an official nginx config for this docker regsitry but no caddy one.
What I have so far is not much but works fine for pull & push:
registry.example.com {
	tls mail@example.com
	basicauth / user password
	proxy /v2/ :2202 { #could be any port
		proxy_header X-Forwarded-Proto {scheme}
		proxy_header X-Forwarded-For {host}
		proxy_header Host {host}
Maybe somebody has already done this with caddy and can help?
Thanks!
Can you share the specific errors you are getting ?
I’m very sorry I forgot to do that.
Error response from daemon: Login: 404 Not Found
 (Code: 404; Headers: map[Date:[Tue, 19 Jul 2016 22:10:11 GMT] Content-Length:[14] Content-Type:[text/plain; charset=utf-8] Server:[Caddy] X-Content-Type-Options:[nosniff]])
Thanks!
Is /v2/ part of the url going upstream ? You can omit it with without.
Ok, I tried it like this but it fails. I think the problem is more likely to be some of the headers not being passed on?!
proxy / :2202 {
	without /v2
That was very simple:
    tls aioslike@example.com
    basicauth /v2 aios 12345
	proxy /v2 registry:5000 {
With version 0.9, replace proxy_header with header_upstream and remove those 3 lines in favor of the transparent preset. :wink:
Can you take some example for that?
Simply this:
Thank you all for replying!
transparent is awesome and simplifies proxying a lot, thanks!
I’ve added logs and in there this gets written:
172.17.0.20 - [27/Jul/2016:19:32:19 +0000] "GET /v2/ HTTP/1.1" 401 17
172.17.0.20 - [27/Jul/2016:19:32:19 +0000] "GET /v1/_ping HTTP/1.1" 404 14
172.17.0.20 - [27/Jul/2016:19:32:19 +0000] "POST /v1/users/ HTTP/1.1" 404 14
So it seems like drone isn’t able to authenticate. Strangely when I do docker push and docker pull it works just fine. So it might be drone in the end. I’ll ask those guys, if they know any auth problems.
Thanks for that!)))
