/srv # caddy version
with docker-composer and docker file:
FROM caddy:2-builder AS builder
RUN xcaddy build \
--with github.com/caddy-dns/duckdns
FROM caddy:2
ENTRYPOINT ["/usr/bin/caddy"]
CMD ["docker-proxy"]
version: '3'
vaultwarden:
image: vaultwarden/server:latest
container_name: vw_vaultwarden
restart: always
- SIGNUPS_ALLOWED=true
- INVITATIONS_ALLOWED=false
- WEBSOCKET_ENABLED=true
- LOG_FILE=/var/log/docker/bitwarden.log
- ./vaultwarden/data:/data
image: mg/caddy:2
build:
context: .
container_name: vw_caddy
restart: always
- 80:80 # Needed for the ACME HTTP-01 challenge.
- 443:443
- ./caddy/config:/config
- ./caddy/data:/data
- DOMAIN=https://mgcl1n1.duckdns.org
- DUCKDNS_TOKEN=<mytocken>
- LOG_FILE=/data/access.log
Running on Manjaro:
Linux mgcl1n32 5.15.19-1-MANJARO #1 SMP PREEMPT Tue Feb 1 16:58:17 UTC 2022 x86_64 GNU/Linux
docker version:
Client:
Version: 20.10.12
API version: 1.41
Go version: go1.17.5
Git commit: e91ed5707e
Built: Mon Dec 13 22:31:40 2021
OS/Arch: linux/amd64
Context: default
Experimental: true
Server:
Engine:
Version: 20.10.12
API version: 1.41 (minimum version 1.12)
Git commit: 459d0dfbbb
Built: Mon Dec 13 22:30:43 2021
Experimental: false
containerd:
Version: v1.5.9
GitCommit: 1407cab509ff0d96baa4f0eb6ff9980270e6e620.m
runc:
Version: 1.1.0
GitCommit: v1.1.0-0-g067aaf85
docker-init:
Version: 0.19.0
GitCommit: de40ad0
docker exec -it vw_caddy ps -eaf
PID USER TIME COMMAND
1 root 0:00 caddy run --config /etc/caddy/Caddyfile --adapter caddyfil
15 root 0:00 sh
29 root 0:00 ps -eaf
Paste command here.
{$DOMAIN}:443 {
level DEBUG
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
# Use the ACME HTTP-01 challenge to get a cert for the configured domain.
dns duckdns {$DUCKDNS_TOKEN}
# This setting may have compatibility issues with some browsers
# (e.g., attachment downloading on Firefox). Try disabling this
# if you encounter issues.
# Notifications redirected to the WebSocket server
reverse_proxy /notifications/hub vw_vaultwarden:3012
# Proxy everything else to Rocket
reverse_proxy vw_vaultwarden:80 {
# Send the true remote IP to Rocket, so that vaultwarden can put this in the
# log, so that fail2ban can ban the correct IP.
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
curl command fails with the following error:
$curl -ikvL https://localhost
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* Closing connection 0
caddy container log:
{"level":"info","ts":1645178530.6221776,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1645178530.6233735,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1645178530.6240795,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1645178530.6242585,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1645178530.6242585,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1645178530.6244261,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000302b60"}
{"level":"info","ts":1645178530.624526,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mgcl1n1.duckdns.org"]}
{"level":"info","ts":1645178530.6245608,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1645178530.6249325,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1645178530.625241,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1645178530.6252549,"msg":"serving initial configuration"}
I have tried to user --insecure option with curl:
curl --trace - --insecure https://localhost/
== Info: Trying 127.0.0.1:443...
== Info: Connected to localhost (127.0.0.1) port 443 (#0)
== Info: ALPN, offering h2
== Info: ALPN, offering http/1.1
=> Send SSL data, 5 bytes (0x5)
0000: 16 03 01 02 00 .....
== Info: TLSv1.3 (OUT), TLS handshake, Client hello (1):
=> Send SSL data, 512 bytes (0x200)
0000: 01 00 01 fc 03 03 97 06 72 be 3b ac 88 ab cf be ........r.;.....
0010: 5a 6c 96 14 87 6d c5 9b 60 51 d4 2b a4 1a 84 37 Zl...m..`Q.+...7
0020: b3 dc 88 90 4a 47 20 49 6d a9 ed cb 82 58 48 6c ....JG Im....XHl
0030: 58 7a dc 43 e8 4b fd 31 49 1d 14 49 2b 58 ad 5f Xz.C.K.1I..I+X._
0040: 1f 29 c7 5a fa e3 72 00 3e 13 02 13 03 13 01 c0 .).Z..r.>.......
0050: 2c c0 30 00 9f cc a9 cc a8 cc aa c0 2b c0 2f 00 ,.0.........+./.
0060: 9e c0 24 c0 28 00 6b c0 23 c0 27 00 67 c0 0a c0 ..$.(.k.#.'.g...
0070: 14 00 39 c0 09 c0 13 00 33 00 9d 00 9c 00 3d 00 ..9.....3.....=.
0080: 3c 00 35 00 2f 00 ff 01 00 01 75 00 00 00 0e 00 <.5./.....u.....
0090: 0c 00 00 09 6c 6f 63 61 6c 68 6f 73 74 00 0b 00 ....localhost...
00a0: 04 03 00 01 02 00 0a 00 0c 00 0a 00 1d 00 17 00 ................
00b0: 1e 00 19 00 18 33 74 00 00 00 10 00 0e 00 0c 02 .....3t.........
00c0: 68 32 08 68 74 74 70 2f 31 2e 31 00 16 00 00 00 h2.http/1.1.....
00d0: 17 00 00 00 31 00 00 00 0d 00 30 00 2e 04 03 05 ....1.....0.....
00e0: 03 06 03 08 07 08 08 08 09 08 0a 08 0b 08 04 08 ................
00f0: 05 08 06 04 01 05 01 06 01 03 03 02 03 03 01 02 ................
0100: 01 03 02 02 02 04 02 05 02 06 02 00 2b 00 09 08 ............+...
0110: 03 04 03 03 03 02 03 01 00 2d 00 02 01 01 00 33 .........-.....3
0120: 00 26 00 24 00 1d 00 20 dc 80 c0 81 fe f3 04 4b .&.$... .......K
0130: 75 5d 05 3b 2d 9b c5 8c 28 1a 9e 94 4a 43 e9 c6 u].;-...(...JC..
0140: 4a 69 43 20 10 4f 0d 0e 00 15 00 b4 00 00 00 00 JiC .O..........
0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
<= Recv SSL data, 5 bytes (0x5)
0000: 15 03 03 00 02 .....
== Info: TLSv1.3 (IN), TLS alert, internal error (592):
<= Recv SSL data, 2 bytes (0x2)
0000: 02 50 .P
== Info: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
== Info: Closing connection 0
I have also checked certificates in caddy container:
/data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mgcl1n1.duckdns.org # pwd
/data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mgcl1n1.duckdns.org # ls -ltr
total 16
-rw------- 1 root root 227 Feb 18 08:00 mgcl1n1.duckdns.org.key
-rw------- 1 root root 158 Feb 18 08:00 mgcl1n1.duckdns.org.json
-rw------- 1 root root 5329 Feb 18 08:00 mgcl1n1.duckdns.org.crt
