[Docker] Help with react-router paths
I have a dockerized react-vite app using react-router-dom, my domain name is https://nascent.dev.
When I try to access paths such as /library or /chapter (so https://nascent.dev/library) for example I get the page I am looking for, but the problem arises when I refresh the page or try to access it using the URL I get a blank page with a 404 error.
I looked into it and it was recommended to append file_server to the Caddyfile or even the try_files {path} /index.html command but unfortunately I don’t know how I can do this with a containerized environment.
404 - The requested path could not be found
alpine2.7.5
docker ubuntu, stack: react, react-router, vite
b. Caddyfile:
nascent.dev {
    reverse_proxy nascent-frontend:8080 {
        header_down Strict-Transport-Security max-age: 31536000
c. docker-compose.yml file:
version: '3'
  nascent-api:
    container_name: nascent-api
    build:
      context: ./bai
      dockerfile: Dockerfile
      - "3000:3000"
  nascent-frontend:
    container_name: nascent-frontend
    build:
      context: ./mythril
      - "8080:8080"
    image: caddy/caddy:2.7.5-alpine
    container_name: caddy-nascent
    - $PWD/site:/srv
    - caddy_data:/data
    - caddy_config:/config
  caddy_data:
  caddy_config:
Yeah, try_files can only be used when Caddy has access to the files, but you’re using reverse_proxy here so that’s not possible.
You’ll need to configure your upstream server. I think you need to configure appType. See Shared Options | Vite
Wow, I feel so dumb right now. I was using the npm package serve to have my front-end running which caused all this.
Thank you for highlighting that the problem might be related to vite rather than Caddy otherwise I’d have unnecessarily spend more time on it! lol
