Docker compose - container infinitely restarting
caddy:2.4.2-builder
Ubuntu 20.04 LTS
DigitalOcean droplet
Docker 20.10.2
Both docker-compose.yml and Caddyfile located in ~/Caddy/
docker-compose up -d
version: "3.7"
    image: caddy:2.4.2-builder
      - .Caddyfile:/etc/caddy/Caddyfile
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
7.synthfleshop.casa {
        reverse_proxy 127.0.0.1:8096
When I use docker ps I can see the container is constantly restarting. I can’t docker exec into the container because of this also, nor can I reach https://7.synthfleshop.casa.
CONTAINER ID   IMAGE                 COMMAND     CREATED         STATUS                          PORTS     NAMES
2279e7444df1   caddy:2.4.2-builder   "/bin/sh"   2 minutes ago   Restarting (0) 36 seconds ago             caddy_caddy_1
I’ve tried using different ports in Caddyfile and docker-compose.yml, different Caddy images, and using bind mounts instead of Docker-managed volumes.
https://hub.docker.com/_/caddy
The builder image variant is not meant to be used for running Caddy. It’s just an image which contains the build tools to make a custom build of Caddy. Please read the docs on Docker.
