By cloning the following repository and following the README instructions:
Docker Compose
In case Github link is not enough:
git clone git@github.com:dunglas/symfony-docker.git sf-docker
cd sf-docker
docker-compose build --pull --no-cache
docker-compose up
Go to https://localhost
docker-compose.yaml
version: "3.4"
php:
build:
context: .
target: symfony_php
args:
SYMFONY_VERSION: ${SYMFONY_VERSION:-}
SKELETON: ${SKELETON:-symfony/skeleton}
STABILITY: ${STABILITY:-stable}
- php_socket:/var/run/php
healthcheck:
interval: 10s
timeout: 3s
retries: 3
start_period: 30s
# Run "composer require symfony/orm-pack" to install and configure Doctrine ORM
DATABASE_URL: postgresql://${POSTGRES_USER:-symfony}:${POSTGRES_PASSWORD:-ChangeMe}@database:5432/${POSTGRES_DB:-app}?serverVersion=${POSTGRES_VERSION:-13}
# Run "composer require symfony/mercure-bundle" to install and configure the Mercure integration
MERCURE_URL: ${CADDY_MERCURE_URL:-http://caddy/.well-known/mercure}
MERCURE_PUBLIC_URL: https://${SERVER_NAME:-localhost}/.well-known/mercure
MERCURE_JWT_SECRET: ${CADDY_MERCURE_JWT_SECRET:-!ChangeMe!}
build:
context: .
target: symfony_caddy
depends_on:
- php
SERVER_NAME: ${SERVER_NAME:-localhost, caddy:80}
MERCURE_PUBLISHER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeMe!}
MERCURE_SUBSCRIBER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeMe!}
- caddy_data:/data
- caddy_config:/config
# HTTP
- target: 80
published: ${HTTP_PORT:-80}
protocol: tcp
# HTTPS
- target: 443
published: ${HTTPS_PORT:-443}
protocol: tcp
# HTTP/3
- target: 443
published: ${HTTP3_PORT:-443}
protocol: udp
# Mercure is installed as a Caddy module, prevent the Flex recipe from installing another service
###> symfony/mercure-bundle ###
###< symfony/mercure-bundle ###
###> doctrine/doctrine-bundle ###
database:
image: postgres:${POSTGRES_VERSION:-13}-alpine
POSTGRES_DB: ${POSTGRES_DB:-app}
# You should definitely change the password in production
POSTGRES_PASSWORD: ${POSTGRES_PASSWORD:-ChangeMe}
POSTGRES_USER: ${POSTGRES_USER:-symfony}
- db-data:/var/lib/postgresql/data:rw
# You may use a bind-mounted host directory instead, so that it is harder to accidentally remove the volume and lose all your data!
# - ./docker/db/data:/var/lib/postgresql/data:rw
###< doctrine/doctrine-bundle ###
pgadmin:
container_name: pgadmin_container
image: dpage/pgadmin4
links:
- database
depends_on:
- database
PGADMIN_DEFAULT_EMAIL: '${PGADMIN_DEFAULT_EMAIL:-pgadmin4@pgadmin.org}'
PGADMIN_DEFAULT_PASSWORD: '${PGADMIN_DEFAULT_PASSWORD:-adminstsapi}'
- 'pgadmin:/root/.pgadmin'
- '${PGADMIN_PORT:-5050}:80'
php_socket:
caddy_data:
caddy_config:
db-data:
pgadmin:
# Debug
{$DEBUG}
# HTTP/3 support
servers {
protocol {
experimental_http3
{$SERVER_NAME}
log
route {
root * /srv/app/public
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Allow anonymous subscribers (double-check that it's what you want)
anonymous
# Enable the subscription API (double-check that it's what you want)
subscriptions
# Extra directives
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
push
php_fastcgi unix//var/run/php/php-fpm.sock
encode zstd gzip
I am trying to point all subdomains (*.localhost) to localhost, not as a redirect but I will be extracting the subdomain in my Symfony app. I was able to do this outside of Docker by running Caddy via Homebrew and the Symfony app via php local dev server with the following in the Caddyfile:
*.localhost {
reverse_proxy localhost:8000
And setting a default URL in config/packages/dev/framework.yaml:
framework:
router:
default_uri: 'https://localhost'
How can I achieve the same thing with a docker-ized app? Many thanks in advance!
"level":"error",
"ts":1640819019.8104544,
"logger":"http.log.error",
"msg":"dial tcp: lookup localhost,: no such host",
"request":{
"remote_addr":"172.23.0.1:59338",
"proto":"HTTP/2.0",
"method":"GET",
"host":"hello.localhost",
"uri":"/hello",
"headers":{
"Sec-Ch-Ua-Platform":[
"\"macOS\""
"Pragma":[
"no-cache"
"Cache-Control":[
"no-cache"
"Dnt":[
"1"
"Upgrade-Insecure-Requests":[
"1"
"Sec-Fetch-Dest":[
"document"
"Sec-Ch-Ua-Mobile":[
"?0"
"Accept-Language":[
"en-GB,en;q=0.9,en-US;q=0.8"
"User-Agent":[
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36 Edg/96.0.1054.62"
"Sec-Fetch-Site":[
"none"
"Sec-Fetch-Mode":[
"navigate"
"Sec-Fetch-User":[
"?1"
"Sec-Ch-Ua":[
"\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"96\", \"Microsoft Edge\";v=\"96\""
"Accept":[
"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Accept-Encoding":[
"gzip, deflate, br"
"tls":{
"resumed":false,
"version":772,
"cipher_suite":4865,
"proto":"h2",
"proto_mutual":true,
"server_name":"hello.localhost"
"duration":0.000286095,
"status":502,
"err_id":"cgczcyd19",
"err_trace":"reverseproxy.statusError (reverseproxy.go:886)"
Caddyfile:
# Debug
{$DEBUG}
# HTTP/3 support
servers {
protocol {
experimental_http3
# wildcard subdomain
*.{$SERVER_NAME} {
reverse_proxy {$SERVER_NAME}
# {$SERVER_NAME}
log
route {
mercure {
# Publisher JWT key
anonymous
subscriptions
# Extra directives
vulcain
push
encode zstd gzip
