v2.4.6
docker-compose (one compose file for the entire stack)
Digital Ocean droplet running Ubuntu 20.04, Docker 20.10.7, docker-compose version 1.25.0
'''docker-compose down && docker-compose up -d
version: '3'
proxy:
image: caddy:alpine
container_name: proxy
restart: always
- 443:443
- $PWD/caddy/data:/data
- $PWD/caddy/config:/config
- DOMAIN={}
- EMAIL={} # Email used for ACME registration
- LOG_FILE=$PWD/access.log
vaultwarden:
image: vaultwarden/server:alpine
container_name: vaultwarden
restart: always
- ./vw-data:/data
linkding:
image: sissbruecker/linkding:latest
container_name: linkding
restart: always
- /srv/linkding:/etc/linkding/data
default:
external:
vault.{$DOMAIN}:443 {
level INFO
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
# Use the ACME HTTP-01 challenge to get a cert for the configured domain.
tls {$EMAIL}
# This setting may have compatibility issues with some browsers
# (e.g., attachment downloading on Firefox). Try disabling this
# if you encounter issues.
# Notifications redirected to the WebSocket server
reverse_proxy /notifications/hub vaultwarden:3012
# Proxy everything else to Rocket
reverse_proxy vaultwarden:80 {
# Send the true remote IP to Rocket, so that vaultwarden can put this in the
# log, so that fail2ban can ban the correct IP.
links.{$DOMAIN}:80 {
reverse_proxy linkding:9090
I can get vaultwarden to work properly through it’s subdomain (vault.domain) and it persists as it should through restarts. curl output:
root@ubuntu-s-1vcpu-1gb-nyc3-01:/srv# curl -v vault.{}
* Trying {}...
* TCP_NODELAY set
* Connected to vault.{} ({}) port 80 (#0)
> GET / HTTP/1.1
> Host: vault.{}
> User-Agent: curl/7.68.0
< Connection: close
< Location: https://vault.{}/
< Server: Caddy
< Date: Thu, 21 Apr 2022 17:36:32 GMT
< Content-Length: 0
* Closing connection 0
I can also get linkding (and this applies to everything except vaultwarden) to work if I host it separately (for example, if I type {DOMAIN}:9090, I will get the linkding interface), so I know the problem isn’t with the service.
But when I try to go to the new subdomain (link.{DOMAIN}, it fails 100% of the time.
root@ubuntu-s-1vcpu-1gb-nyc3-01:/srv# curl -v links.{}
* Trying {}...
* TCP_NODELAY set
* Connected to links.{} ({}) port 80 (#0)
> GET / HTTP/1.1
> Host: links.{}
< HTTP/1.1 302 Found
< Content-Language: en
< Content-Length: 0
< Content-Type: text/html; charset=utf-8
< Location: /bookmarks
< Referrer-Policy: same-origin
< Server: Caddy
< Vary: Accept-Language
< X-Content-Type-Options: nosniff
< X-Frame-Options: DENY
< Date: Thu, 21 Apr 2022 17:36:11 GMT
* Connection #0 to host links.{} left intact
I have tried multiple iterations of reverse_proxy with different settings and multiple services (several different bookmark hosting services, calibre-web, nextcloud, bookstack, and others) and they all have the same issue. I have searched this forum and elsewhere for a solution, but none of them fix the problem.
I have checked my DNS settings and made sure that I have A records pointing to the server, and they match the other functional A records, so it’s not a DNS issue. The issue persists through multiple devices (tried mobile, my local computer, and directly from within the server) and they all have the same issue, so it’s not a cache problem.
I’ve hidden the domain because the WHOIS contains PII (I cannot use domain privacy with .us domains), and I already had my IP switched twice because malicious abuse of the shared Digital Ocean IPs, so I’ve removed those too.
