Docker Caddy with CloudFlare Full mode returns Invalid SSL certificate Error code 526
I have developed two e-commerce website using MERN stack.
one is already deployed using docker and it’s running on Digitalocean without any issue.
What I am trying to do is deploy another e-commerce website using docker ( different instance ) on same Digitalocean droplet (same IP address)
I am using
Cloudflare - For DNS configuration DigitalOcean droplet - to deploy my docker instances (frontend and backend) Caddy - For get automatic HTTPS
This is how my docker, dockcer compose and caddy file looks like
caddy file
www.treblemart.com:443 {
    tls <my gmail address>
    root * /srv
    route {
        reverse_proxy /api* products-backend:5100
        try_files {path} {path}/ /index.html
docker file
first Stage
FROM node:16 AS builder
WORKDIR /usr/src/app
COPY ./package.json ./
COPY ./yarn.lock ./
RUN npm install
COPY . .
ARG BASE_URL
ENV REACT_APP_BASE_URL=${BASE_URL} NODE_ENV=${NODE_ENV}
RUN yarn build
second stage
FROM caddy:2.4.6
ARG CADDYFILE
COPY ${CADDYFILE} /etc/caddy/Caddyfile
COPY --from=builder /usr/src/app/build/ /srv
EXPOSE 80
EXPOSE 443
dockcer compose
version: "3"
      products-frontend:
         image: products-frontend-prod:${ENV}
         ports: "81:80"
               "8001:443"
      treble-ecommerce-variant-products-app
      caddy-data:/data
      caddy-config:/config
      /root/treble/uploads/trebleecommercevariantproductsuploads/:/srv/trebleecommercevariantproductsuploads
   products-backend:
      image: products-backend
      env_file: ./products-backend/config/${ENV}.env
       ports: "5100:5000"
                /var/log/services/products-backend/:/var/log/services/products-backend/
               /root/treble/uploads/productsuploads/:/usr/src/app/productsuploads
           treble-ecommerce-variant-products-app:
                driver: bridge
       mongo-data:
       driver: local
  caddy-data:
      driver: local
  caddy-config:
      driver: local
Now I am getting Issue Invalid SSL certificate Error code 526. But I can’t figure out why.
my previous website is running on
ports: "80"
       "443".
So I did port binding for my new website as mentioned on docker compose file.
I am trying to deploy my new website on same droplet ( same IP address )
I have configured Cloudflare DNS to my new domain ( same droplet in digitalocean )
Anyone can help me to resolve this Invalid SSL certificate Error code 526 issue?
When you use full mode, Cloudflare redirects HTTP requests to HTTPS, which means that ACME issuers can’t reach Caddy because they get served a redirect for HTTP requests instead of reaching Caddy to solve the ACME HTTP challenge.
Instead, use whatever mode allows HTTP traffic as well, or just use the grey-cloud mode (i.e. no proxy, only DNS).
Hi @francislavoie Thanks for quick response.
but when I am changed it to Flexible mode I am getting ERR_TOO_MANY_REDIRECTS error.
And on the frontend logs I can see this
{"level":"error","ts":1689222332.993821,"logger":"tls.obtain","msg":"will retry","error":"[www.treblemart.com] Obtain: [www.treblemart.com] solving challenge: www.treblemart.com: [www.treblemart.com] authorization failed: HTTP 0  -  (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":15.900283337,"max_duration":2592000}
I don’t use Cloudflare myself. But I think you need to use Full, but turn off “Always Use HTTPS”.
Hi @francislavoie
After changing to caddy file like this
    tls internal
    root * /srv
    route {
tls → internal
I saw in the backend there is no error now. but Invalid SSL certificate Error code 526 issue is still there.
can you please explain after configure tls internal do I need to provide CA from server itself?
Remove tls internal, it will prevent Caddy from ever presenting a publicly trusted HTTPS certificate.
Leave the encryption mode as Full (Strict).
Then, you have two options:
  1. Turn off HTTP->S redirects globally for the Cloudflare site. This option isn’t in the most intuitive place - currently you’ll need to go to SSL/TLS → Edge Certificates.
OR
  1. a. Go to Rules → Configuration Rules and make a new rule. Call it “Disable HTTP->S for well-known URIs” or something similar.
    b. Select “Custom filter expression”. Set Field = URI Path, Operator = Starts With, Value = /.well-known/acme-challenge
    c. Add the “Automatic HTTPS Rewrites (optional)” rule and DISABLE it.
    d. Save and deploy the configuration rule. Now Cloudflare will not redirect HTTP-01 challenges and Caddy can complete them.
Hi @Whitestrake
I am still getting the same error after trying both of your suggestions. Here are logs
Here is the my settings
Did I do something wrorng?
Could you please post those logs as text?
Hi @Whitestrake
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"info","ts":1689733685.3340282,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"admin.treblemart.com","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
treble-ecommerce-variant-products-frontend_1        | {"level":"info","ts":1689733685.3860726,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"www.treblemart.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"error","ts":1689733686.1390095,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"admin.treblemart.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"error","ts":1689733686.1391003,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"admin.treblemart.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1213544587/195841339277","attempt":1,"max_attempts":3}
treble-ecommerce-variant-products-backend_1         | 2023-07-19T02:28:06.559Z info : Connected to mongodb...
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"info","ts":1689733687.725417,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"admin.treblemart.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
treble-ecommerce-variant-products-frontend_1        | {"level":"error","ts":1689733716.7266731,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"www.treblemart.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3031::ac43:87b7: Invalid response from http://www.treblemart.com/.well-known/acme-challenge/IWEN3u0gcTbgk05DviqcjxtfZo2q_3solYb3pHnusbE: 522","instance":"","subproblems":[]}}
treble-ecommerce-variant-products-frontend_1        | {"level":"error","ts":1689733716.7274108,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"www.treblemart.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3031::ac43:87b7: Invalid response from http://www.treblemart.com/.well-known/acme-challenge/IWEN3u0gcTbgk05DviqcjxtfZo2q_3solYb3pHnusbE: 522","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1213544587/195841339387","attempt":1,"max_attempts":3}
treble-ecommerce-variant-products-frontend_1        | {"level":"error","ts":1689733718.0216587,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"www.treblemart.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/"}
treble-ecommerce-variant-products-frontend_1        | {"level":"info","ts":1689733718.023132,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["www.treblemart.com"],"ca":"https://acme.zerossl.com/v2/DV90","account":"treblesolution@gmail.com"}
treble-ecommerce-variant-products-frontend_1        | {"level":"info","ts":1689733718.023534,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["www.treblemart.com"],"ca":"https://acme.zerossl.com/v2/DV90","account":"treblesolution@gmail.com"}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"error","ts":1689733719.1811903,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"admin.treblemart.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3035::6815:1a53: Invalid response from http://admin.treblemart.com/.well-known/acme-challenge/ofU0OaBF7iBwZbIPcIbVCtQZUAdPXLMFknfvjpGVLp0: 522","instance":"","subproblems":[]}}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"error","ts":1689733719.1819825,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"admin.treblemart.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3035::6815:1a53: Invalid response from http://admin.treblemart.com/.well-known/acme-challenge/ofU0OaBF7iBwZbIPcIbVCtQZUAdPXLMFknfvjpGVLp0: 522","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/1213544587/195841346117","attempt":2,"max_attempts":3}
treble-ecommerce-variant-products-frontend_1        | {"level":"info","ts":1689733720.621203,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"www.treblemart.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"error","ts":1689733721.048058,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"admin.treblemart.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[admin.treblemart.com] solving challenges: admin.treblemart.com: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-v02.api.letsencrypt.org/acme/order/1213544587/195841422947) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
treble-ecommerce-variant-products-frontend-admin_1  | {"level":"info","ts":1689733721.0491822,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["admin.treblemart.com"],"ca":"https://acme.zerossl.com/v2/DV90","account":"treblesolution@gmail.com"}
Hi @Whitestrake
And my folder structure is like this
Main project :
I
I ____> Frontend admin :
I | ____> Caddyfile
I I _____> Dockerfile
I
I ____> Frontend :
I | ____> Caddyfile
I ____> backend :
Your settings in Cloudflare look correct.
In your logs you get repeated 522 status errors:
Status 522 from Cloudflare indicates that their proxy timed out when attempting to connect to your server, so the next thing for you to troubleshoot is port 80 access to Caddy.
Hi @Whitestrake
Just to double check with you is my Caddyfiles correct?
Admin Caddyfile
admin.treblemart.com:443 {
    tls ***@gmail.com
    root * /srv
    route {
        reverse_proxy treble-ecommerce-variant-products-frontend-admin:8080
        reverse_proxy /api* treble-ecommerce-variant-products-backend:5000
Frontend Caddyfile
    tls ***@gmail.com
    root * /srv
    route {
        reverse_proxy treble-ecommerce-variant-products-frontend:9090
Correct is a strong assurance for me to be able to give for your use case.
I can tell you that they look like valid Caddyfiles, and that I would expect Caddy to be listening on port 80 and 443 in that configuration.
I might personally make a few minor changes, but only in presentational details, by personal preference.
