I have a directory proxy with static files, I change content, or rename but still does not update changes, I tried restart, browser cache, etc, but I can´t solve my problem
All proxy work fine
Access to http://portales.local/Demo/config/igni.json works fine
I’m try change values for igni.json but still not update, trying query params
I try rewrite condition and rename file but not working , I cant access to igni2.json
rewrite /Demo/config/igni2.json /igni2.json
I try change domain to portales.local.com
I trying GET https://portales.local.com/Demo/config/igni2.json does not working but if i try old one https://portales.local.com/Demo/config/igni.json the same value
How can I solve, thank you
2024-03-16T04:38:22.107025148Z {"level":"info","ts":1710563902.106991,"msg":"serving initial configuration"}
2024-03-16T04:38:22.200577547Z {"level":"warn","ts":1710563902.2004135,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"99d3fb7d-1116-498b-8a4b-ad1c22977bb9","try_again":1710650302.2004113,"try_again_in":86399.999999547}
2024-03-16T04:38:22.200606436Z {"level":"info","ts":1710563902.2005546,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1710564002.4846964,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.29.0.1","remote_port":"41420","client_ip":"172.29.0.1","proto":"HTTP/1.1","method":"GET","host":"portales.local","uri":"/Demo/config/igni.json?run=cache","headers":{"Accept-Language":["es-419,es;q=0.9"],"Cookie":[],"Connection":["keep-alive"],"Pragma":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Cache-Control":["no-cache"],"Upgrade-Insecure-Requests":["1"],"Accept-Encoding":["gzip, deflate"]}},"method":"GET","uri":"/config/igni.json?run=cache"}
{"level":"debug","ts":1710564002.48505,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"angular:4200","total_upstreams":1}
{"level":"debug","ts":1710565329.770169,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"172.29.0.1","remote_port":"36724","client_ip":"172.29.0.1","proto":"HTTP/1.1","method":"GET","host":"portales.local","uri":"/Demo/config/igni2.json?asas","headers":{"Connection":["keep-alive"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Accept-Encoding":["gzip, deflate"],"Accept-Language":["es-419,es;q=0.9"],"Cookie":[]}},"method":"GET","uri":"/config/igni2.json?asas"}
caddy:2.7.6-alpine
Docker
Fedora 38, Docker
docker-compose up -d
proxy:
container_name: portal-caddy
image: caddy:2.7.6-alpine
- 443:443
- ./www/:/home/www/
auto_https off
http://portales.local {
header Access-Control-Allow-Credentials "true"
header Access-Control-Allow-Headers "*"
header Access-Control-Allow-Source-Origin "*"
header Cache-Control "no-cache, no-store, must-revalidate"
handle_path /Demo* {
root * /home/www
rewrite /Demo/config/igni.json /igni.json
reverse_proxy http://angular:4200
reverse_proxy http://next:3000
/home/www/igni.json
"demo" : "value",
"demo2" : "value"
