I want to know do caddy support client certificate check using oscp, if do how to configure it? I cannot find any information in documentation talk about client certificate revocation checking
Welcome Alex –
Caddy automatically staples OCSP for all qualifying certificates. If it is managing the certificate, it will also attempt to replace a revoked certificate. There is no configuration needed by you.
Edit: I just read the word “client” (this is what happens when I don’t get enough sleep). There’s an open issue for this: Allow revocation list for client cert auth · Issue #2341 · caddyserver/caddy · GitHub
