DNS resolution not working inside docker container
Caddy/Vaultwarden no longer recognizes the letscrypted certificate. So I tried to fix the problem, and eventually I threw away the conatiner and images and rebuilt from scratch with the same docker-compose file. Now Caddy is trying to get a letscrypt certificate but can’t resolve the DNS name.
ERR ts=1744800786.5669062 logger=tls.obtain msg=will retry error=[solarsystem.ddnss.de] Obtain: account pre-registration callback: performing EAB credentials request: Post "https://api.zerossl.com/acme/eab-credentials-email": dial tcp: lookup api.zerossl.com on 127.0.0.11:53: read udp 127.0.0.1:39013->127.0.0.11:53: i/o timeout attempt=12 retrying_in=1800 elapsed=7687.709121117 max_duration=2592000
When I get into the docker container using a shell, I tried to do some tests to find out what the problem is:When I get into the docker container using a shell, I tried to do some tests to find out what the problem is, I see that the problem is with DNS:
/bin # ping 9.9.9.9
PING 9.9.9.9 (9.9.9.9): 56 data bytes
64 bytes from 9.9.9.9: seq=0 ttl=59 time=15.574 ms
64 bytes from 9.9.9.9: seq=1 ttl=59 time=11.729 ms
64 bytes from 9.9.9.9: seq=2 ttl=59 time=11.563 ms
64 bytes from 9.9.9.9: seq=3 ttl=59 time=10.392 ms
^C
--- 9.9.9.9 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 10.392/12.314/15.574 ms
/bin # nslookup google.com
;; connection timed out; no servers could be reached
/bin # cat /etc/resolv.conf
nameserver 127.0.0.11
options ndots:0
I am running Caddy using docker.
Docker, on a raspberry pi
docker-compose up -d
version: '3'
  bitwarden:
    image: vaultwarden/server:latest
    container_name: vaultwarden
    restart: always
      - WEBSOCKET_ENABLED=true
      - SIGNUPS_ALLOWED=false
      - DOMAIN=https://solarsystem.ddnss.de
      - SMTP_HOST=posteo.de
      - SMTP_FROM=XXX@posteo.de
      - SMTP_PORT=587
      - SMTP_SECURITY=starttls
      - SMTP_USERNAME=XXX@posteo.de
      - SMTP_PASSWORD=***
      - ADMIN_TOKEN=***
      - ./bw-data:/data
    labels:
      - "com.centurylinklabs.watchtower.enable=true"
    image: caddy:2
    restart: always
      - 80:80  # Needed for the ACME HTTP-01 challenge.
      - 443:443
      - ./caddy-config:/config
      - ./caddy-data:/data
      - DOMAIN=solarsystem.ddnss.de
      - EMAIL=****@posteo.de       # The email address to use for ACME registration.
      - LOG_FILE=/data/access.log
    labels:
                level ERROR
{$DOMAIN}:443 {
                level ERROR
                output file {$LOG_FILE} {
                        roll_size 10MB
                        roll_keep 10
        # Use the ACME HTTP-01 challenge to get a cert for the configured domain.
        tls {$EMAIL}
        # This setting may have compatibility issues with some browsers
        # (e.g., attachment downloading on Firefox). Try disabling this
        # if you encounter issues.
        # Notifications redirected to the WebSocket server
        reverse_proxy /notifications/hub vaultwarden:3012
        # Proxy everything else to Rocket
        reverse_proxy bitwarden:80 {
                # Send the true remote IP to Rocket, so that bitwarden_rs can put this in the
                # log, so that fail2ban can ban the correct IP.
Inside Docker containers, the DNS server is 127.0.0.11:53. Being able to ping 9.9.9.9 is irrelevant.
This is ultimately a Docker DNS/network problem. I’m not sure why Docker DNS fails inside the container. Our images aren’t doing anything special inside the container.
