Xieneus
(Sarp Carter)
March 17, 2024, 7:36pm
1
I cant start Caddy Web Server with DNS provider.
I built with xcaddy, command:
xcaddy build --with github.com/caddy-dns/cloudflare
And this is my Caddyfile:
https://getseopro.com {
root * /var/www/html/public
encode zstd gzip
dns cloudflare mytokenwashere
resolvers 1.1.1.1
# reverse_proxy localhost:3000
I tried with cloduflare and powerdns (gmysql backend, bind backend) and still i have an error like this;
Error: adapting config using caddyfile: parsing caddyfile tokens for 'tls': getting module named 'dns.providers.cloudflare': module not registered: dns.providers.cloudflare, at Caddyfile:7
Centos Stream 8
dnf install 'dnf-command(copr)'
dnf copr enable @caddy/caddy
dnf install caddy
encode zstd gzip
resolvers 1.1.1.1
Xieneus
(Sarp Carter)
March 17, 2024, 7:41pm
2
And i tried global version with this config file:
acme_dns cloudflare mytokenrlywashere
encode zstd gzip
Error Output:
Error: adapting config using caddyfile: parsing caddyfile tokens for 'acme_dns': getting module named 'dns.providers.cloudflare': module not registered: dns.providers.cloudflare, at Caddyfile:2
You built it, but did you replace your actual binary with the built one? It’ll just output the new binary to your current directory, you then need to move it where it needs to go.
Since you installed using dnf, the binary is at /usr/bin/caddy. You can replace it there, but keep in mind next time you update your packages, your custom binary will be wiped out.
You could instead move it to /usr/bin/caddy.custom or something like that, then override the default command with a systemd override (see Keep Caddy Running — Caddy Documentation ).
Xieneus
(Sarp Carter)
March 17, 2024, 10:13pm
4
DNS module became operational. Now I need to work on this error;
2024/03/17 22:12:25.685 WARN tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "5905667c-136c-4c01-9292-9e8e4d9b4edc", "try_again": "2024/03/18 22:12:25.685", "try_again_in": 86399.999999177}
2024/03/17 22:12:25.685 INFO tls finished cleaning storage units
2024/03/17 22:12:25.685 INFO tls.obtain lock acquired {"identifier": "getseoranker.com"}
2024/03/17 22:12:25.686 INFO tls.obtain obtaining certificate {"identifier": "getseoranker.com"}
2024/03/17 22:12:25.688 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["getseoranker.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/03/17 22:12:25.688 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["getseoranker.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/03/17 22:12:26.702 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "getseoranker.com", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2024/03/17 22:12:27.471 ERROR tls.issuance.acme.acme_client cleaning up solver {"identifier": "getseoranker.com", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.getseoranker.com\" (usually OK if presenting also failed)"}
2024/03/17 22:12:27.647 ERROR tls.obtain could not get certificate from issuer {"identifier": "getseoranker.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[getseoranker.com] solving challenges: presenting for challenge: adding temporary record for zone \"getseoranker.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme-v02.api.letsencrypt.org/acme/order/1623656287/253172410667) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2024/03/17 22:12:27.647 INFO tls.issuance.zerossl waiting on internal rate limiter {"identifiers": ["getseoranker.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2024/03/17 22:12:27.647 INFO tls.issuance.zerossl done waiting on internal rate limiter {"identifiers": ["getseoranker.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2024/03/17 22:12:28.796 INFO tls.issuance.zerossl.acme_client trying to solve challenge {"identifier": "getseoranker.com", "challenge_type": "dns-01", "ca": "https://acme.zerossl.com/v2/DV90"}
2024/03/17 22:12:29.500 ERROR tls.issuance.zerossl.acme_client cleaning up solver {"identifier": "getseoranker.com", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.getseoranker.com\" (usually OK if presenting also failed)"}
2024/03/17 22:12:29.815 ERROR tls.obtain could not get certificate from issuer {"identifier": "getseoranker.com", "issuer": "acme.zerossl.com-v2-DV90", "error": "[getseoranker.com] solving challenges: presenting for challenge: adding temporary record for zone \"getseoranker.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/klRo-b7mEFRi0lkxhTv_hg) (ca=https://acme.zerossl.com/v2/DV90)"}
2024/03/17 22:12:29.815 ERROR tls.obtain will retry {"error": "[getseoranker.com] Obtain: [getseoranker.com] solving challenges: presenting for challenge: adding temporary record for zone \"getseoranker.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/klRo-b7mEFRi0lkxhTv_hg) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 4.129486612, "max_duration": 2592000}
Thanks @francislavoie
This usually means your Cloudflare token was invalid. Make sure to follow the instructions on GitHub - libdns/cloudflare: Cloudflare provider implementation for libdns to correctly set up your token.
