Dns module not loaded after installed with xcaddy
Seems like cloudlflare dns module is not being installed with xcaddy with im trying to receive wildcard certificate from cloudflare.
Jan 26 15:32:00 caddy caddy[310]: LOGNAME=caddy
Jan 26 15:32:00 caddy caddy[310]: USER=caddy
Jan 26 15:32:00 caddy caddy[310]: INVOCATION_ID=12b7d863c0f74b5fb4ab8613dd09eb19
Jan 26 15:32:00 caddy caddy[310]: JOURNAL_STREAM=8:7738992
Jan 26 15:32:00 caddy caddy[310]: SYSTEMD_EXEC_PID=310
Jan 26 15:32:00 caddy caddy[310]: {"level":"info","ts":1737901920.9207475,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Jan 26 15:32:00 caddy caddy[310]: Error: adapting config using caddyfile: parsing caddyfile tokens for 'acme_dns': getting module named 'dns.providers.cloudflare': module not registered: dns.providers.cl>
Jan 26 15:32:00 caddy systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 15:32:00 caddy systemd[1]: caddy.service: Failed with result 'exit-code'.
Jan 26 15:32:00 caddy systemd[1]: Failed to start caddy.service - Caddy.
Debian 12
Proxmox LXC - Bare metal
1cpu 1gb ram 4gb disk
installed using this
As a service
*.redacted.com:443 {
                dns cloudflare redacted
        @food2 host food2.redacted.com
        handle @food2 {
                encode zstd gzip
                reverse_proxy 192.168.1.23:9925
caddy list-modules shows that its cloudflare module is not installed.
root@caddy:/opt# caddy list-modules
admin.api.load
admin.api.metrics
admin.api.pki
admin.api.reverse_proxy
caddy.adapters.caddyfile
caddy.config_loaders.http
caddy.filesystems
caddy.listeners.http_redirect
caddy.listeners.proxy_protocol
caddy.listeners.tls
caddy.logging.cores.mock
caddy.logging.encoders.append
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.cookie
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.hash
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.filter.query
caddy.logging.encoders.filter.regexp
caddy.logging.encoders.filter.rename
caddy.logging.encoders.filter.replace
caddy.logging.encoders.json
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.storage.file_system
events
http
http.authentication.hashes.bcrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.copy_response
http.handlers.copy_response_headers
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.intercept
http.handlers.invoke
http.handlers.log_append
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.tracing
http.handlers.vars
http.ip_sources.static
http.matchers.client_ip
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.tls
http.matchers.vars
http.matchers.vars_regexp
http.precompressed.br
http.precompressed.gzip
http.precompressed.zstd
http.reverse_proxy.selection_policies.client_ip_hash
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.query
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.selection_policies.weighted_round_robin
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
http.reverse_proxy.upstreams.a
http.reverse_proxy.upstreams.multi
http.reverse_proxy.upstreams.srv
pki
tls
tls.ca_pool.source.file
tls.ca_pool.source.http
tls.ca_pool.source.inline
tls.ca_pool.source.pki_intermediate
tls.ca_pool.source.pki_root
tls.ca_pool.source.storage
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.certificates.load_storage
tls.client_auth.verifier.leaf
tls.get_certificate.http
tls.get_certificate.tailscale
tls.handshake_match.local_ip
tls.handshake_match.remote_ip
tls.handshake_match.sni
tls.handshake_match.sni_regexp
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.leaf_cert_loader.file
tls.leaf_cert_loader.folder
tls.leaf_cert_loader.pem
tls.leaf_cert_loader.storage
tls.permission.http
tls.stek.distributed
tls.stek.standard
  Standard modules: 124
  Non-standard modules: 0
  Unknown modules: 0
xcaddy module install
root@caddy:~# xcaddy build --with github.com/caddy-dns/cloudflare
2025/01/26 16:34:38 [INFO] absolute output file path: /root/caddy
2025/01/26 16:34:38 [INFO] Temporary folder: /tmp/buildenv_2025-01-26-1634.473662680
2025/01/26 16:34:38 [INFO] Writing main module: /tmp/buildenv_2025-01-26-1634.473662680/main.go
package main
import (
        caddycmd "github.com/caddyserver/caddy/v2/cmd"
        // plug in Caddy modules here
        _ "github.com/caddyserver/caddy/v2/modules/standard"
        _ "github.com/caddy-dns/cloudflare"
func main() {
        caddycmd.Main()
2025/01/26 16:34:38 [INFO] Initializing Go module
2025/01/26 16:34:38 [INFO] exec (timeout=0s): /usr/local/bin/go mod init caddy
go: creating new go.mod: module caddy
go: to add module requirements and sums:
        go mod tidy
2025/01/26 16:34:38 [INFO] Pinning versions
2025/01/26 16:34:38 [INFO] exec (timeout=0s): /usr/local/bin/go get -v github.com/caddyserver/caddy/v2
go: added github.com/beorn7/perks v1.0.1
go: added github.com/caddyserver/caddy/v2 v2.9.1
go: added github.com/caddyserver/certmagic v0.21.6
go: added github.com/caddyserver/zerossl v0.1.3
go: added github.com/cespare/xxhash/v2 v2.3.0
go: added github.com/francoispqt/gojay v1.2.13
go: added github.com/go-task/slim-sprig v0.0.0-20230315185526-52ccab3ef572
go: added github.com/google/pprof v0.0.0-20231212022811-ec68065c825e
go: added github.com/google/uuid v1.6.0
go: added github.com/klauspost/cpuid/v2 v2.2.9
go: added github.com/libdns/libdns v0.2.2
go: added github.com/mholt/acmez/v3 v3.0.0
go: added github.com/miekg/dns v1.1.62
go: added github.com/onsi/ginkgo/v2 v2.13.2
go: added github.com/prometheus/client_golang v1.19.1
go: added github.com/prometheus/client_model v0.5.0
go: added github.com/prometheus/common v0.48.0
go: added github.com/prometheus/procfs v0.12.0
go: added github.com/quic-go/qpack v0.5.1
go: added github.com/quic-go/quic-go v0.48.2
go: added github.com/zeebo/blake3 v0.2.4
go: added go.uber.org/mock v0.4.0
go: added go.uber.org/multierr v1.11.0
go: added go.uber.org/zap v1.27.0
go: added go.uber.org/zap/exp v0.3.0
go: added golang.org/x/crypto v0.31.0
go: added golang.org/x/exp v0.0.0-20240506185415-9bf2ced13842
go: added golang.org/x/mod v0.18.0
go: added golang.org/x/net v0.33.0
go: added golang.org/x/sync v0.10.0
go: added golang.org/x/sys v0.28.0
go: added golang.org/x/term v0.27.0
go: added golang.org/x/text v0.21.0
go: added golang.org/x/time v0.7.0
go: added golang.org/x/tools v0.22.0
go: added google.golang.org/protobuf v1.35.1
2025/01/26 16:34:40 [INFO] exec (timeout=0s): /usr/local/bin/go get -v github.com/caddy-dns/cloudflare github.com/caddyserver/caddy/v2
go: downloading github.com/caddy-dns/cloudflare v0.0.0-20240703190432-89f16b99c18e
go: downloading github.com/libdns/cloudflare v0.1.2-0.20240604123710-0549667a10ab
go: added github.com/caddy-dns/cloudflare v0.0.0-20240703190432-89f16b99c18e
go: added github.com/libdns/cloudflare v0.1.2-0.20240604123710-0549667a10ab
2025/01/26 16:34:42 [INFO] exec (timeout=0s): /usr/local/bin/go get -v
2025/01/26 16:34:53 [INFO] Build environment ready
2025/01/26 16:34:53 [INFO] Building Caddy
2025/01/26 16:34:53 [INFO] exec (timeout=0s): /usr/local/bin/go mod tidy -e
2025/01/26 16:34:53 [INFO] exec (timeout=0s): /usr/local/bin/go build -o /root/caddy -ldflags -w -s -trimpath -tags nobadger,nomysql,nopgx
2025/01/26 16:34:56 [INFO] Build complete: ./caddy
2025/01/26 16:34:56 [INFO] Cleaning up temporary folder: /tmp/buildenv_2025-01-26-1634.473662680
././caddy version
xcaddy only builds caddy, but you still need to move it to a location within $PATH. I see the proxmox scripts assume apt package manager, so it’s running on a Debian-derivative. Follow the instructions here:
