DNS challenge failing with SERVFAIL for Caddy with Cloudflare module
1. Caddy version (caddy version): v2.5.1
2. How I run Caddy: Through docker container compiled with cloudflare module, available at GitHub Packages & Docker Hub. Dockerfile & source repo available here.
Docker container. Host OS & System: Ubuntu 20.04 LTS.
docker compose up -d
docker container logs -t -f caddy
version: '3'
    image: 'roxonic/caddy:2.5.1'
      CF_API_EMAIL: "mail@example.com"
      CF_API_TOKEN: "Secret_Token"
      - ./sites:/srv
      - ./data:/data
      - ./config:/config
      - /etc/timezone:/etc/timezone:ro
      dockernet-bridge:
         ipv4_address: 172.20.11.1
      dockernet-ipvlan:
         ipv4_address: 172.20.1.1
    dns:
      - 172.20.11.0
    restart: always
  dockernet-bridge:
    external: true
  dockernet-ipvlan:
    external: true
	email {env.CF_API_EMAIL}
	acme_dns cloudflare {env.CF_API_TOKEN}
	servers :443 {
		protocol {
			experimental_http3
*.roxonic.net {
	@smokeping host smokeping.roxonic.net
	handle @smokeping {
		reverse_proxy 172.20.1.8:80
	# Fallback for otherwise unhandled domains
		abort
Caddy is failing to obtain a certificate from either LetsEncrypt or ZeroSSL. Here are some interesting things that I’ve observed:
  1. Caddy is able to access my zone through the API credentials successfully. How I know this? Because right after starting the caddy container, I can see that my token was used by caddy on the API tokens page as it shows Last used: a few seconds ago.
  2. Caddy can also add the acme TXT record just fine. Whenever I start the container, I can see multiple logs showing the DNS record was created, and then 3 to 4 seconds later it gets deleted. This can be seen from the audit logs section of cloudflare dashboard (under manage account).
2022-05-31T11:43:39.190113919Z {"level":"warn","ts":1653997419.1900136,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":13}
2022-05-31T11:43:39.191012960Z {"level":"info","ts":1653997419.1909132,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
2022-05-31T11:43:39.191257244Z {"level":"info","ts":1653997419.191199,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
2022-05-31T11:43:39.191322483Z {"level":"info","ts":1653997419.1911993,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003a20e0"}
2022-05-31T11:43:39.191334695Z {"level":"info","ts":1653997419.1912217,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
2022-05-31T11:43:39.191732906Z {"level":"info","ts":1653997419.191681,"logger":"http","msg":"enabling experimental HTTP/3 listener","addr":":443"}
2022-05-31T11:43:39.191789161Z {"level":"info","ts":1653997419.1917357,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
2022-05-31T11:43:39.191798462Z {"level":"info","ts":1653997419.19176,"logger":"tls","msg":"finished cleaning storage units"}
2022-05-31T11:43:39.191840749Z {"level":"info","ts":1653997419.1917984,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
2022-05-31T11:43:39.191974927Z {"level":"debug","ts":1653997419.1919231,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":true,"tls":true}
2022-05-31T11:43:39.191992710Z {"level":"debug","ts":1653997419.1919606,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
2022-05-31T11:43:39.192028445Z {"level":"info","ts":1653997419.1919963,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.roxonic.net"]}
2022-05-31T11:43:39.192300908Z {"level":"info","ts":1653997419.1922388,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
2022-05-31T11:43:39.192309967Z {"level":"info","ts":1653997419.1922507,"msg":"serving initial configuration"}
2022-05-31T11:43:39.192481558Z {"level":"info","ts":1653997419.1924295,"logger":"tls.obtain","msg":"acquiring lock","identifier":"*.roxonic.net"}
2022-05-31T11:43:39.199012587Z {"level":"info","ts":1653997419.1988788,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.roxonic.net"}
2022-05-31T11:43:39.199575930Z {"level":"debug","ts":1653997419.1994972,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
2022-05-31T11:43:40.244836416Z {"level":"debug","ts":1653997420.244686,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["658"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:40 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
2022-05-31T11:43:40.528443536Z {"level":"debug","ts":1653997420.528327,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Tue, 31 May 2022 11:43:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002AcrDuc95t6wHLfqhueFzQZBSR8W-uT48j8GRBG1-8CQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
2022-05-31T11:43:40.836530370Z {"level":"debug","ts":1653997420.8364105,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-acct","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["567235036"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["320"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf>;rel=\"terms-of-service\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/acct/567235036"],"Replay-Nonce":["00011HTG9vt8TghmTfne3wcgVZ98olJb-jA73Sd1Zqh3zR0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
2022-05-31T11:43:40.837103714Z {"level":"info","ts":1653997420.8370197,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.roxonic.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"mail@example.com"}
2022-05-31T11:43:40.837122879Z {"level":"info","ts":1653997420.8370402,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.roxonic.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"mail@example.com"}
2022-05-31T11:43:41.195216553Z {"level":"debug","ts":1653997421.1951027,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["567235036"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["337"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:41 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/567235036/93524766186"],"Replay-Nonce":["0002n0s6X5AZJHSr9oYsycrJ-_cGmTdJxHQKyI0-Ipj_IQg"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
2022-05-31T11:43:41.485706631Z {"level":"debug","ts":1653997421.4855986,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/114523941506","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["567235036"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["385"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:41 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002WPZaqdstvxO8CWciVxB_oJehtQGgMZGOw4ddrKYE23Q"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
2022-05-31T11:43:41.485824142Z {"level":"info","ts":1653997421.4857597,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.roxonic.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
2022-05-31T11:43:47.625503974Z {"level":"debug","ts":1653997427.625386,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/114523941506","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["567235036"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["389"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:47 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001SHUIya9BtQ70m2Ur5BxdiPuuvlBMLwXy_-p6Wx0FbnI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
2022-05-31T11:43:47.625570173Z {"level":"error","ts":1653997427.6255155,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.roxonic.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.roxonic.net] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of _acme-challenge.roxonic.net: NS igor.ns.cloudflare.com. returned SERVFAIL for _acme-challenge.roxonic.net. (order=https://acme-v02.api.letsencrypt.org/acme/order/567235036/93524766186) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2022-05-31T11:43:47.625586367Z {"level":"debug","ts":1653997427.6255298,"logger":"tls.obtain","msg":"trying issuer 2/2","issuer":"acme.zerossl.com-v2-DV90"}
2022-05-31T11:43:49.289439376Z {"level":"info","ts":1653997429.28935,"logger":"tls.issuance.zerossl","msg":"generated EAB credentials","key_id":"N6sUFdX2A0VE7tGq-8zVPg"}
2022-05-31T11:43:59.076210034Z {"level":"debug","ts":1653997439.0761042,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme.zerossl.com/v2/DV90","headers":{"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["645"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:43:59 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]},"status_code":200}
2022-05-31T11:44:05.780184408Z {"level":"debug","ts":1653997445.7800715,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme.zerossl.com/v2/DV90/newNonce","headers":{"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Type":["application/octet-stream"],"Date":["Tue, 31 May 2022 11:44:05 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["3o4s--8J8jRf3rM5mT61aTdkcgGKuLOZt4iZeMr5AeE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]},"status_code":200}
2022-05-31T11:44:11.826933407Z {"level":"debug","ts":1653997451.8268108,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/newAccount","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store","max-age=-1"],"Content-Length":["579"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:44:11 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/account/N6sUFdX2A0VE7tGq-8zVPg"],"Replay-Nonce":["EvTDzJWHwP3Mrj7r_YxH5KRgmnfsQzdAa0nLWmKA7CY"],"Server":["nginx"],"Status":[""],"Strict-Transport-Security":["max-age=15552000"]},"status_code":201}
2022-05-31T11:44:11.827590962Z {"level":"info","ts":1653997451.8272316,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.roxonic.net"],"ca":"https://acme.zerossl.com/v2/DV90","account":"mail@example.com"}
2022-05-31T11:44:11.827616438Z {"level":"info","ts":1653997451.8272593,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.roxonic.net"],"ca":"https://acme.zerossl.com/v2/DV90","account":"mail@example.com"}
2022-05-31T11:44:20.837596359Z {"level":"debug","ts":1653997460.837503,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/newOrder","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store","max-age=-1"],"Content-Length":["275"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:44:20 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/C53EccWndJRT94tT0tz_JA"],"Replay-Nonce":["jXxSLoif0-SX-oLo_xAHb6PKhaSPs4HVaav-WG-D_00"],"Server":["nginx"],"Status":[""],"Strict-Transport-Security":["max-age=15552000"]},"status_code":201}
2022-05-31T11:44:21.426272549Z {"level":"debug","ts":1653997461.4261749,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/gLL_U19Nyd5m1Xxis_gHpw","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["295"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:44:21 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["SQb2-Q8qiPjofGHFs8d8NWHweib7AmtPW9hPrKPlJ_s"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]},"status_code":200}
2022-05-31T11:44:21.426346695Z {"level":"info","ts":1653997461.4262722,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.roxonic.net","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
2022-05-31T11:44:33.371488816Z {"level":"debug","ts":1653997473.3713396,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/gLL_U19Nyd5m1Xxis_gHpw","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["139"],"Content-Type":["application/json"],"Date":["Tue, 31 May 2022 11:44:33 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["UnSwRBIv7REgecP2grHMuyEQvOx-muwbG_4jeEkgJEg"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]},"status_code":200}
2022-05-31T11:44:33.371523860Z {"level":"error","ts":1653997473.371437,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.roxonic.net","issuer":"acme.zerossl.com-v2-DV90","error":"[*.roxonic.net] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of _acme-challenge.roxonic.net: NS igor.ns.cloudflare.com. returned SERVFAIL for _acme-challenge.roxonic.net. (order=https://acme.zerossl.com/v2/DV90/order/C53EccWndJRT94tT0tz_JA) (ca=https://acme.zerossl.com/v2/DV90)"}
2022-05-31T11:44:33.371551876Z {"level":"error","ts":1653997473.3714733,"logger":"tls.obtain","msg":"will retry","error":"[*.roxonic.net] Obtain: [*.roxonic.net] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of _acme-challenge.roxonic.net: NS igor.ns.cloudflare.com. returned SERVFAIL for _acme-challenge.roxonic.net. (order=https://acme.zerossl.com/v2/DV90/order/C53EccWndJRT94tT0tz_JA) (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":54.172561157,"max_duration":2592000}
2022-05-31T11:44:43.695975432Z {"level":"info","ts":1653997483.695863,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
2022-05-31T11:44:43.696007229Z {"level":"warn","ts":1653997483.6958883,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
2022-05-31T11:44:43.698325860Z {"level":"info","ts":1653997483.6982532,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003a20e0"}
2022-05-31T11:44:43.698341086Z {"level":"info","ts":1653997483.6982796,"logger":"tls.obtain","msg":"releasing lock","identifier":"*.roxonic.net"}
2022-05-31T11:44:43.698407829Z {"level":"error","ts":1653997483.6983466,"msg":"unable to clean up lock in storage backend","signal":"SIGTERM","storage":"FileStorage:/data/caddy","lock_key":"issue_cert_*.roxonic.net","error":"remove /data/caddy/locks/issue_cert_wildcard_.roxonic.net.lock: no such file or directory"}
2022-05-31T11:44:43.698417656Z {"level":"error","ts":1653997483.6983783,"logger":"tls","msg":"job failed","error":"*.roxonic.net: obtaining certificate: context canceled"}
2022-05-31T11:44:43.699554974Z {"level":"info","ts":1653997483.6995027,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
2022-05-31T11:44:43.699566323Z {"level":"info","ts":1653997483.6995122,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Don’t know what I’m missing but I’ve tried a lot, starting from recreating token to rebuilding the image, trying with other domains (*.roxonic.com), replacing environment variable in caddyfile with actual values, changing DNS resolver for the container manually… none worked so far.
6. Links to relevant resources: DNS challenge failing with SERVFAIL for Caddy with Cloudflare module DNS challenge failing with SERVFAIL for Caddy with Cloudflare module
Can anybody help me with this?
This problem is almost/entirely similar to this thread.
Did you try to configure resolvers to 1.1.1.1 in your Caddyfile?
	resolvers 1.1.1.1
If that doesn’t work, you can try turning off propagation checks altogether (since it’s really just Caddy trying to verify that writing the TXT record worked before moving on, but it’s not required to check).
	issuer acme {
		propagation_timeout -1
	issuer zerossl {
(you’d need to configure both issuers to keep issuer fallback, since propagation_timeout can only be configured under issuer)
Okay, after tinkeing with the Caddyfile for an hour, here’s what I’ve found:
Setting resolvers to 1.1.1.1 doesn’t change anything. It still shows me the same SERVFAIL as can be seen in the above logs.
Setting the propagation_timeout to -1 gives me a very weird result:
{"level":"error","ts":1654037808.8948798,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.roxonic.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 403 urn:ietf:params:acme:error:unauthorized - No TXT record found at _acme-challenge.roxonic.net"}
But while restarting/recreating the conatiner multiple times, only once the ZeroSSL verification went through. LetsEncrypt said the exact same thing: ..... No TXT record found at _acme-challenge.roxonic.net
I don’t know why I did this, but I thought of setting tls config like this:
	issuer acme {
		propagation_delay 60s
	issuer zerossl {
I am not even sure if this is a logically correct config or if it makes any sense, but this did the trick (atleast for me). I was successfully able to get LetsEncrypt certificates.
2022-05-31T23:03:00.164087553Z {"level":"info","ts":1654038180.1639962,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/********"}
2022-05-31T23:03:01.513701741Z {"level":"info","ts":1654038181.5136006,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/***************"
Thanks @francislavoie for giving me the hints with your reply.
