DNS and Caddy configuration synchronization issue during AWS ECS deployments
During automated deployments in AWS ECS Fargate, we’re experiencing DNS resolution issues with Caddy. Our setup consists of two containers in the same task definition: an API (Node.js) and Caddy as reverse proxy. The workflow is:
  1. ECS deploys a new task
  2. A script updates Route53 A record with the new task’s IP and waits for INSYNC status
  3. API container starts and waits for health check
  4. Caddy container starts and proxies to the API (127.0.0.1:3000)
After a CI/CD pipeline deployment, Caddy seems unable to properly handle DNS resolution, and requests fail. However, if we manually stop the task and let ECS create a new one automatically, everything works perfectly. This suggests there might be an issue with how Caddy handles DNS resolution during the initial deployment.
  "level": "info",
  "ts": 1734084306.6575897,
  "msg": "selected upstream",
  "dial": "127.0.0.1:3000",
  "total_upstreams": 1
Caddy 2.8.4-alpine
  • AWS ECS Fargate
  • Two containers in same task definition
  • Container 1: Node.js API
  • Container 2: Caddy reverse proxy
  • AWS Route53 for DNS management
container_definitions = jsonencode([
    name      = "caddy"
    image     = "caddy:2.8.4-alpine"
    essential = true
    command = [
      "sh", "-c", <<-EOT
        echo '{
            output stdout
            format json
            level DEBUG
          storage file_system {
            root "/data/caddy"
        https://api-v1.domain.com {
          reverse_proxy 127.0.0.1:3000 {
            header_up Access-Control-Allow-Origin "*"
            header_up Access-Control-Allow-Methods "*"
            header_up Access-Control-Allow-Headers "*"
            header_up Access-Control-Allow-Credentials "true"
            header_up Access-Control-Expose-Headers "*"
            health_uri /api/health
            health_interval 60s
            max_fails 10
        }' > /etc/caddy/Caddyfile && sleep 40 &&
      EOT
    portMappings = [
        containerPort = 80
        containerPort = 443
caddy
    output stdout
    format json
    level DEBUG
    root "/data/caddy"
    health_interval 60s
    max_fails 10
The key aspect is that manually stopping and letting ECS recreate the task always fixes the issue, suggesting there might be something in how Caddy handles DNS resolution during the initial deployment that differs from subsequent task creations.
You haven’t actually shown a problem here. I don’t understand what you mean. That debug log is normal behaviour of the proxy.
Hello @francislavoie , thanks for being interested in my issue.
The main problem might not be directly caused by caddy. It can be just a configuration issue or just a lack of understanding by my side. The key here might be the knowledge of how AWS/ECS works in IP/DNS resolutions every when a new service is deployed.
The main problem is this:
So, after a CI/CD deployment, there is a new IP generated, but DNS route 53 is updated so it should be no problem becuase caddy is configured by dns and not by IP. BUT it actually doesn’t work. Caddy does his work but it goes to nowhere. (I have struggling with logs but I can’t have proper logs to show my problem. getting better logs can be a nice help for me here)
