1. Caddy version (caddy version): v2.1.1 h1:X9k1+ehZPYYrSqBvf/ocUgdLSRIuiNiMo7CvyGUQKeA=
terminal
Manjaro Linux x64
sudo caddy run
auto_https off
(theheaders) {
header Host {host}
header X-Forwarded-For {remote_host}
header X-Forwarded-Proto {scheme}
header X-Url-Scheme {scheme}
header X-Forwarded-Host {host}
header X-Real-IP {remote_host}
header Referrer-Policy "same-origin"
header X-XSS-Protection "1; mode=block"
header Referrer-Policy no-referrer-when-downgrade
import theheaders
route /api* {
reverse_proxy :8000
route /media* {
reverse_proxy :8000
route /admin* {
reverse_proxy :8000
route /static* {
reverse_proxy :8000
reverse_proxy :3000
Django API, that is hosted on :8000 port, has a Cookie-Set header that puts a cookie to browser. The problem is, it only works if I directly visit the API, but when I make an AJAX request there’s no any Cookie-... header. Although, headers defined in theheaders are present in the localhost/... (any page that is handled by a (Next.js) app served on :3000):
If I visit the Django API directly, e.g. open it in the browser (http://localhost/api), I get the cookie set properly:
I suspect there’s an issue in that I do proxying wrong. Can I pipe headers from api to the /* somehow?
I tried putting import theheaders to every route, adding header: +Set-Cookie to theheaders config - none of them helped.
