caddy:2.3.0 in Docker
Running in Docker Container. Docker version 20.10.5, build 55c4c88 on Ubuntu 18.04.5 LTS
docker run -d -it --restart="always" \
-v /home/ocom/apps/data/caddy2/Caddyfile:/etc/caddy/Caddyfile \
-v /home/ocom/apps/data/caddy2/data:/data \
-v /home/ocom/apps/data/caddy2/conf:/config \
-v /home/ocom/apps/data/caddy2/log:/log \
--network bridge \
--name caddy2 -p 80:80 -p 443:443 -e CADDY_OPTIONS="--email letsencrypt@xxx --agree" -d caddy2:ocom
FROM caddy:2.3.0-builder AS builder
RUN xcaddy build --with github.com/caddy-dns/lego-deprecated
FROM caddy:2.3.0-alpine
trainingdb.qa2.ocom.com.au {
output file /log/access.trainingdb.qa2.ocom.com.au.log {
rotate_size 100 # Rotate a log when it reaches 100 MB
rotate_age 14 # Keep rotated log files for 14 days
rotate_keep 10 # Keep at most 10 rotated log files
# read_timeout 20h
tls admin@ocom.com.au {
# dns lego_deprecated linode
reverse_proxy /* 172.17.0.12:80 {
# websocket
keepalive off
header_up X-Forwarded-For {host}
header_up X-Real-IP {http.reverse-proxy.upstream.address}
header_up X-Forwarded-Host {http.request.host}
health_path /dockerStatus/
health_status 2XX
health_interval 7s
health_timeout 60s
lb_policy least_conn
# fail_timeout 2s
max_fails 10
lb_try_interval 5s
encode gzip zstd
I have used Caddy 1 successfully for a few years so I am trying to upgrade to V2
I am finding with my health check that it’s not working with Django because by default it wants the hostname to match. But it seems the header_up is Not used in the health check is that correct? Has that changed? I have looked in the documentation but I could not find anything.
My Django app has this in the settings
VHOST = os.environ.get('VIRTUAL_HOST')
ALLOWED_HOSTS = [VHOST]
Where the VIRTUAL_HOST env var is passed into the Docker container.
On my Django container I get this
[pid: 27|app: 0|req: 1/1] 172.17.0.14 () {32 vars in 386 bytes} [Fri Mar 19 05:45:45 2021] GET /dockerStatus/ => generated 26 bytes in 1108 msecs (HTTP/1.1 400) 2 headers in 67 bytes (1 switches on core 0)
[pid: 26|app: 0|req: 1/2] 172.17.0.14 () {32 vars in 386 bytes} [Fri Mar 19 05:45:52 2021] GET /dockerStatus/ => generated 26 bytes in 1117 msecs (HTTP/1.1 400) 2 headers in 67 bytes (1 switches on core 0)
[pid: 26|app: 0|req: 2/3] 172.17.0.14 () {32 vars in 386 bytes} [Fri Mar 19 05:45:59 2021] GET /dockerStatus/ => generated 26 bytes in 46 msecs (HTTP/1.1 400) 2 headers in 67 bytes (1 switches on core 3)
[pid: 26|app: 0|req: 3/4] 172.17.0.14 () {32 vars in 386 bytes} [Fri Mar 19 05:46:06 2021] GET /dockerStatus/ => generated 26 bytes in 38 msecs (HTTP/1.1 400) 2 headers in 67 bytes (1 switches on core 1)
Because it’s doing the check but rejecting it.
I would appreciate any help or suggestions.
I have tried different header_up incantations but nothing seems to work.
