plorenzo
(Pablo)
#1
I’m trying to serve a Discourse forum using Caddy (with several other sites), after reading some ways of doing it I decide to follow the Caddyfile examples repo. (I believe is how this site do it)
I’m getting the following 502 error:
[ERROR 502 /] read tcp [::1]:32864->[::1]:8080: read: connection reset by peer
Caddyfile
soporte.colmecar.es {
proxy / localhost:8080 {
errors /home/plorenzo/dev/logs/errorsDiscourse.log
Any idea of what the problem is?
plorenzo
(Pablo)
#2
Found the problem !
Digging into docker logs I saw that Nginx was trying to get certificates, to fix it I just commented a few line in app.yml
# - "templates/web.ssl.template.yml"
# - "templates/web.letsencrypt.ssl.template.yml"
After rebuild the container ./launcher rebuild app
and it’s good to go
system
(system)
closed
#3
