Official docker container
auto_https off
default_sni localhost
:8000 {
tls server.crt server.key {
client_auth {
mode request
trusted_ca_cert_file ca.crt
@websockets {
header Connection *Upgrade*
header Upgrade websocket
# to rtpengine
reverse_proxy @websockets 127.0.0.1:9901
reverse_proxy /api/* 127.0.0.1:8080
I want to use Caddy for mutual TLS auth for components which do not have DNS names (on an internal network). This is apparently causing issues with strict SNI host checking when clients access caddy via https urls that only have IP addresses. The result is a 403 response when using an IP address. I need to disable this strict SNI checking and I know the dangers involved.
No errors but this tipped me off:
{"level":"info","ts":1619472260.329402,"logger":"http","msg":"enabling strict SNI-Host matching because TLS client auth is configured","server_name":"srv0"}
Tried setting default_sni to localhost, ip addresses etc.
Read the code and found this: line of code which implies that if I manage to set strict_sni_host to false, it would not be flipped on by client auth. But the Caddyfile does not allow to set it as true or false explicitly. Do I need to rewrite my config in JSON or YAML for this?
