I’m trying to move my website to caddy, but some paths on my site need to be accesible over http, not https
for example i want requests to Home - Ownwebsite were serverd over http and not automatically redirected to https://mywebsite.com/api
Are there any options to disable TLS not for whole site, but only for some paths on it?
I’m not sure if this is your issue, but I had to call an api from a webhost that didnt work with the latest TLS when calling file_get_contents or curl from php .
This is what I used when I set up a small website for temporary image sharing (a la imgur), I wanted to set it up to use with ShareX but the program does not like newer protocols.
I’m also facing the same issue as one of my instrumented application is using Prometheus. Prometheus can get the metrics using TLS, but it leaks file descriptors, making it unstable (like, it’s eating file descriptors like M&Ms). So I would like to have a single endpoint /metrics to be served over HTTP and not HTTPS. Is that possible ? Or not ?
My need is not to disable HTTPS for said endpoint, but to disable auto-redirect, so Prometheus can fetch the data.
Including a separate configuration for http://your.domain.com/metrics in your Caddyfile will cause Caddy to use the more specific configuration block over the generic your.domain.com.
Requests to https:// will still go to the generic block, because it won’t match the http:// of the specific block.
