I’m sorry that i didn’t respond for such a long time.
I didn’t see the help form for some reason, but here you go:
v2.1.1
Docker Container
I guess this must be the default caddy one, at least portainer tells me so
I’m not using docker compose for Caddy but maybe the output of docker inspect is sufficient too? If not tell me please
"AppArmorProfile": "docker-default",
"Args": [
"run",
"--config",
"/etc/caddy/Caddyfile",
"--adapter",
"caddyfile"
"Config": {
"AttachStderr": false,
"AttachStdin": false,
"AttachStdout": false,
"Cmd": [
"caddy",
"run",
"--config",
"--adapter",
"caddyfile"
"Domainname": "",
"Entrypoint": null,
"Env": [
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"CADDY_DIST_COMMIT=80870b227ded910971ecace4a0c136bf0ef46342",
"CADDY_VERSION=v2.1.1",
"XDG_CONFIG_HOME=/config",
"XDG_DATA_HOME=/data"
"ExposedPorts": {
"2019/tcp": {},
"443/tcp": {},
"80/tcp": {}
"Hostname": "c323a69d3f0e",
"Image": "caddy:latest",
"Labels": {
"org.opencontainers.image.description": "a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go",
"org.opencontainers.image.documentation": "https://caddyserver.com/docs",
"org.opencontainers.image.licenses": "Apache-2.0",
"org.opencontainers.image.source": "https://github.com/caddyserver/caddy-docker",
"org.opencontainers.image.title": "Caddy",
"org.opencontainers.image.url": "https://caddyserver.com",
"org.opencontainers.image.vendor": "Light Code Labs",
"org.opencontainers.image.version": "v2.1.1"
"OnBuild": null,
"OpenStdin": false,
"StdinOnce": false,
"Tty": false,
"User": "",
"Volumes": {
"/config": {},
"/data": {},
"/etc/caddy/Caddyfile": {},
"/var/www/html/snipeit": {}
"WorkingDir": "/srv"
"Created": "2020-08-25T21:30:59.320913485Z",
"Driver": "overlay2",
"ExecIDs": null,
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/1ee3e4d638e017dd1f813f7fcf4b50efd0ee143e8dfd1b30ad48a2ecdf1058ec-init/diff:/var/lib/docker/overlay2/9b5c8a314b0a660a8b1e8bb53f1648b5f18959f9c0b3a5d51df3b335ce4b8315/diff:/var/lib/docker/overlay2/8d6d616d5c0c92493ea3c712e19ae960b51e399a86eca4d28257b5aa1a9d05ed/diff:/var/lib/docker/overlay2/9609bf1a944080c8dc228d432c604c1ff398ceab82b10e068eed6e19dfcc0493/diff:/var/lib/docker/overlay2/795f09abb1502bc3951d54bc9eacc4ce5b2f0f60b009943dc0a107f9c0673f58/diff:/var/lib/docker/overlay2/5209d370e2327ad2ec53ffb8461ba3a456d3ec6300c24cf04d427000300ec4fd/diff",
"MergedDir": "/var/lib/docker/overlay2/1ee3e4d638e017dd1f813f7fcf4b50efd0ee143e8dfd1b30ad48a2ecdf1058ec/merged",
"UpperDir": "/var/lib/docker/overlay2/1ee3e4d638e017dd1f813f7fcf4b50efd0ee143e8dfd1b30ad48a2ecdf1058ec/diff",
"WorkDir": "/var/lib/docker/overlay2/1ee3e4d638e017dd1f813f7fcf4b50efd0ee143e8dfd1b30ad48a2ecdf1058ec/work"
"Name": "overlay2"
"HostConfig": {
"AutoRemove": false,
"Binds": [
"/nfs/freenas/caddy/caddy2-data:/data",
"/nfs/freenas/caddy/Caddyfile2:/etc/caddy/Caddyfile",
"7531cc5d494b6dbb7b86fec8fe3f21c3142d5def3e45caefb363bec2856fd6ac:/config",
"3cc455552b6fa62b087d0fb9986ffbb79f727ec9d3ec3e9a822add48850a8acb:/var/www/html/snipeit"
"BlkioDeviceReadBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceWriteIOps": null,
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"CapAdd": [
"AUDIT_WRITE",
"CHOWN",
"DAC_OVERRIDE",
"FOWNER",
"FSETID",
"KILL",
"MKNOD",
"NET_BIND_SERVICE",
"NET_RAW",
"SETFCAP",
"SETGID",
"SETPCAP",
"SETUID",
"SYS_CHROOT"
"CapDrop": [
"AUDIT_CONTROL",
"BLOCK_SUSPEND",
"DAC_READ_SEARCH",
"IPC_LOCK",
"IPC_OWNER",
"LEASE",
"LINUX_IMMUTABLE",
"MAC_ADMIN",
"MAC_OVERRIDE",
"NET_ADMIN",
"NET_BROADCAST",
"SYSLOG",
"SYS_ADMIN",
"SYS_BOOT",
"SYS_MODULE",
"SYS_NICE",
"SYS_PACCT",
"SYS_PTRACE",
"SYS_RAWIO",
"SYS_RESOURCE",
"SYS_TIME",
"SYS_TTY_CONFIG",
"WAKE_ALARM"
"Capabilities": null,
"Cgroup": "",
"CgroupParent": "",
"ConsoleSize": [
0,
0
"ContainerIDFile": "",
"CpuCount": 0,
"CpuPercent": 0,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpuShares": 0,
"CpusetCpus": "",
"CpusetMems": "",
"DeviceCgroupRules": null,
"DeviceRequests": null,
"Devices": [],
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": [],
"GroupAdd": null,
"IOMaximumBandwidth": 0,
"IOMaximumIOps": 0,
"IpcMode": "private",
"Isolation": "",
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"Links": null,
"LogConfig": {
"Config": {},
"Type": "json-file"
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"Memory": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"NanoCpus": 0,
"NetworkMode": "bridge",
"OomKillDisable": false,
"OomScoreAdj": 0,
"PidMode": "",
"PidsLimit": null,
"PortBindings": {
"443/tcp": [
"HostIp": "",
"HostPort": "443"
"80/tcp": [
"HostIp": "",
"HostPort": "80"
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"ReadonlyRootfs": false,
"RestartPolicy": {
"MaximumRetryCount": 0,
"Name": "unless-stopped"
"Runtime": "runc",
"SecurityOpt": null,
"ShmSize": 67108864,
"UTSMode": "",
"Ulimits": null,
"UsernsMode": "",
"VolumeDriver": "",
"VolumesFrom": null
"HostnamePath": "/var/lib/docker/containers/38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7/hostname",
"HostsPath": "/var/lib/docker/containers/38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7/hosts",
"Id": "38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7",
"Image": "sha256:90a12b5c957bab94f57aadfd9e655d414ab69443495f22ef430152181ab0aede",
"LogPath": "/var/lib/docker/containers/38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7/38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7-json.log",
"MountLabel": "",
"Mounts": [
"Destination": "/config",
"Driver": "local",
"Mode": "z",
"Name": "7531cc5d494b6dbb7b86fec8fe3f21c3142d5def3e45caefb363bec2856fd6ac",
"Propagation": "",
"RW": true,
"Source": "/var/lib/docker/volumes/7531cc5d494b6dbb7b86fec8fe3f21c3142d5def3e45caefb363bec2856fd6ac/_data",
"Type": "volume"
"Destination": "/data",
"Mode": "",
"Propagation": "rprivate",
"RW": true,
"Source": "/nfs/freenas/caddy/caddy2-data",
"Type": "bind"
"Destination": "/etc/caddy/Caddyfile",
"Mode": "",
"RW": true,
"Source": "/nfs/freenas/caddy/Caddyfile2",
"Type": "bind"
"Destination": "/var/www/html/snipeit",
"Driver": "local",
"Mode": "z",
"Name": "3cc455552b6fa62b087d0fb9986ffbb79f727ec9d3ec3e9a822add48850a8acb",
"Propagation": "",
"RW": true,
"Source": "/var/lib/docker/volumes/3cc455552b6fa62b087d0fb9986ffbb79f727ec9d3ec3e9a822add48850a8acb/_data",
"Type": "volume"
"Name": "/Caddy2",
"NetworkSettings": {
"Bridge": "",
"EndpointID": "d2a5e5d1560d038347ba142709188207d471e9f1b8278294f9f3b6305424c7b4",
"Gateway": "172.17.0.1",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"HairpinMode": false,
"IPAddress": "172.17.0.2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"MacAddress": "02:42:ac:11:00:02",
"Networks": {
"bridge": {
"Aliases": null,
"DriverOpts": null,
"IPAMConfig": {},
"IPPrefixLen": 16,
"IPv6Gateway": "",
"Links": null,
"NetworkID": "3a38b2a7308414580138aa27d46867b05848fc2859a30fd27f08bb406bf76218"
"Ports": {
"2019/tcp": null,
"443/tcp": [
"HostIp": "0.0.0.0",
"HostPort": "443"
"80/tcp": [
"HostPort": "80"
"SandboxID": "e80ab1756886b7ba6a53932a7ba465360ee12f22a77016bc0b236d97c9cf746d",
"SandboxKey": "/var/run/docker/netns/e80ab1756886",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null
"Path": "caddy",
"Platform": "linux",
"Portainer": {
"ResourceControl": {
"Id": 138,
"ResourceId": "38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7",
"SubResourceIds": [],
"Type": 1,
"UserAccesses": [],
"TeamAccesses": [],
"Public": false,
"AdministratorsOnly": true,
"System": false
"ProcessLabel": "",
"ResolvConfPath": "/var/lib/docker/containers/38707399927c241155cf28a3798d35ce8efee09fd7b77f1b94122e31def55ac7/resolv.conf",
"RestartCount": 0,
"State": {
"Dead": false,
"Error": "",
"ExitCode": 0,
"FinishedAt": "2020-09-17T21:40:21.697638829Z",
"OOMKilled": false,
"Paused": false,
"Pid": 3004,
"Restarting": false,
"Running": true,
"StartedAt": "2020-09-17T23:40:59.697598695Z",
"Status": "running"
blackhole:80, pi.hole:80, 0.0.0.0:80 {
root /var/www/html/pihole
#log /var/log/caddy/blackhole.log
rewrite {
ext js
to index.js
proxy / localhost:1180 {
nextcloud.xxx {
header / Strict-Transport-Security "max-age=31536000;"
proxy / 192.168.0.81:8080 {
proxy /sites 192.168.0.81:8080/index.php/apps/cms_pico/pico_proxy/ {
without /sites/
bitwarden.xxx {
proxy / 192.168.0.81:8090 {
rocketchat.xxx {
proxy / 192.168.0.81:3000 {
websocket
onlyoffice.xxx {
proxy / 192.168.0.81:8082 {
websocket
#ipfilter / {
# rule allow
# ip 192.168.0.0/24
I guess i’ve described that enough in my first post.
The logs look something like this:
{"level":"info","ts":1600513475.509498,"logger":"http.log.access","msg":"handled request","request":{"method":"PROPFIND","uri":"/remote.php/caldav/calendars/.../","proto":"HTTP/1.1","remote_addr":"","host":"","headers":{"Accept-Language":["de-de, de;q=0.9"],"Content-Length":["113"],"Connection":["close"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"Content-Type":["application/xml; charset=\"utf-8\""],"Accept-Encoding":["gzip, deflate"],"User-Agent":["Evolution/3.36.4"],"Depth":["0"],"Authorization":["Basic =="]},"tls":{"resumed":true,"version":772,"ciphersuite":4865,"proto":"","proto_mutual":true,"server_name":""}},"common_log":"84.118.97.244 - - [19/Sep/2020:11:04:35 +0000] \"PROPFIND /remote.php/caldav/calendars/-wi/ HTTP/1.1\" 207 409","duration":0.222507821,"size":409,"status":207,"resp_headers":{"Expires":["Thu, 19 Nov 1981 08:52:00 GMT"],"Set-Cookie":["oc_sessionPassphrase=; path=/; secure; HttpOnly; SameSite=Lax","__Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax","__Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict","ocl6bii3x45t=; path=/; secure; HttpOnly; SameSite=Lax"],"Referrer-Policy":["no-referrer"],"Dav":["1, 3, extended-mkcol, calendar-access, calendar-proxy, access-control, calendarserver-principal-property-search, calendar-auto-schedule, calendar-availability"],"X-Permitted-Cross-Domain-Policies":["none"],"Content-Type":["application/xml; charset=utf-8"],"X-Xss-Protection":["1; mode=block"],"X-Robots-Tag":["none"],"Cache-Control":["no-store, no-cache, must-revalidate"],"X-Content-Type-Options":["nosniff"],"Vary":["Brief,Prefer"],"X-Download-Options":["noopen"],"Content-Security-Policy":["default-src 'none';"],"Date":["Sat, 19 Sep 2020 11:04:35 GMT"],"X-Frame-Options":["SAMEORIGIN"],"Server":["Caddy","nginx/1.17.9"],"Strict-Transport-Security":["max-age=31536000;"],"Pragma":["no-cache"]}}
{"level":"info","ts":1600513475.5156312,"logger":"http.log.access","msg":"handled request","request":{"method":"PROPFIND","uri":"/remote.php/caldav/calendars/.../","proto":"HTTP/1.1","remote_addr":"","host":"","headers":{"User-Agent":["Evolution/3.36.4"],"Accept-Encoding":["gzip, deflate"],"Accept-Language":["de-de, de;q=0.9"],"Content-Length":["113"],"Connection":["close"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"Depth":["0"],"Content-Type":["application/xml; charset=\"utf-8\""],"Authorization":["Basic =="]},"tls":{"resumed":true,"version":772,"ciphersuite":4865,"proto":"","proto_mutual":true,"server_name":""}},"common_log":"84.118.97.244 - - [19/Sep/2020:11:04:35 +0000] \"PROPFIND /remote.php/caldav/calendars/ HTTP/1.1\" 207 408","duration":0.229743941,"size":408,"status":207,"resp_headers":{"X-Permitted-Cross-Domain-Policies":["none"],"X-Frame-Options":["SAMEORIGIN"],"Set-Cookie":["oc_sessionPassphrase=; path=/; secure; HttpOnly; SameSite=Lax","__Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax","__Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict","=; path=/; secure; HttpOnly; SameSite=Lax"],"X-Robots-Tag":["none"],"Vary":["Brief,Prefer"],"Server":["Caddy","nginx/1.17.9"],"Strict-Transport-Security":["max-age=31536000;"],"Content-Security-Policy":["default-src 'none';"],"Dav":["1, 3, extended-mkcol, calendar-access, calendar-proxy, access-control, calendarserver-principal-property-search, calendar-auto-schedule, calendar-availability"],"Referrer-Policy":["no-referrer"],"X-Download-Options":["noopen"],"X-Xss-Protection":["1; mode=block"],"Expires":["Thu, 19 Nov 1981 08:52:00 GMT"],"Date":["Sat, 19 Sep 2020 11:04:35 GMT"],"Content-Type":["application/xml; charset=utf-8"],"Cache-Control":["no-store, no-cache, must-revalidate"],"Pragma":["no-cache"],"X-Content-Type-Options":["nosniff"]}}
I would just like to disbale those info logs, because they really spam my output and I can’t see the relevant errors anymore.
