Directive is not ordered?
v2.1.1
Runit
VoidLinux
`./caddy run --adapter caddyfile --config /wiki`
:80
try_files {path}.html
root * /data
webdav {
    root /data
Trying to migrate Caddyfile v1 to Caddyfile v2
run: adapting config using caddyfile: directive 'webdav' is not ordered, so it cannot be used here
Well since I do not understand what this error message means, I just changed the webdav directive to tho one above.
Please take a look at the README for the plugin:
You need to specify the order global option for plugins, or wrap your usage of the plugin’s directive with the route directive, in Caddy v2.
Thanks, that did the trick :slight_smile:
