2.4.1
Debian 10.0
As per install docs
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/gpg.key' | sudo apt-key add -
sudo apt update
sudo apt install caddy
preview.minty.art {
header User-Agent *bot* {
reverse_proxy * localhost:9009
header User-Agent *Bot* {
header User-Agent *Python* {
root * /var/www
output file /var/log/preview.log
The App is a react app, hence og tags cannot be created,
I am trying to figure out how to redirect bots to use a reverse proxy so that I can generate previews
I need to check the “User-Agent” header and given anything with “bot” or “Bot” or “Python” send it to a reverse proxy instead…
(this is on a demo server without the react app - I have figured out how to get the react app working
using try_files {path} /index.html
run: adapting config using caddyfile: parsing caddyfile tokens for ‘header’: /etc/caddy/Caddyfile:12 - Error during parsing: cannot specify headers in both arguments and block
All the examples about redirecting bots seem to be old (Caddy 1.x) so it isn’t really clear where to start here…
