I am trying to set up a machine with different web services on it, each one reachable using different third level domain. All of that using docker.
Since I am more of a front-end guy, I followed a guide that helped me set up n8n and caddy. It worked perfectly, my n8n instance is reachable using my third level domain and it support SSL, that was the main goal for that.
Now I would like to add baserow to the stack and portainer (this one is just optional, but i thought “why not?”)
So here is the docker-compose.yml:
version: "3.7"
image: caddy:latest
- caddy_data:/data
- ${DATA_FOLDER}/caddy_config:/config
- ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
n8n:
image: docker.n8n.io/n8nio/n8n
container_name: n8n
restart: always
- N8N_HOST=${N8N_SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${N8N_SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- n8n_data:/home/node/.n8n
- ${DATA_FOLDER}/local_files:/files
portainer-ce:
- 9443:9443
container_name: portainer
- ${DATA_FOLDER}/portainer_data:/data
image: portainer/portainer-ce:latest
baserow:
container_name: baserow
- BASEROW_PUBLIC_URL=http://${BASEROW_SUBDOMAIN}.${DOMAIN_NAME}/
- baserow_data:/baserow/data
image: baserow/baserow:1.24.2
caddy_data:
external: true
n8n_data:
external: true
portainer_data:
external: true
baserow_data:
external: true
And here’s the Caddyfile:
NOTE: the url are written in this form: sub.example.com and sanitazed for privacy
<n8n_subdomain>.<domain_name> {
reverse_proxy n8n:5678 {
flush_interval -1
<portainer_subdomain>.<domain_name> {
reverse_proxy portainer:9443
<baserow_subdomain>.<domain_name> {
reverse_proxy baserow:3002
Visiting the baserow domain, I got a error 502.
I am not sure what I did wrong. I was able to reach baserow if I set the variable BASEROW_PUBLIC_URL in docker file to the n8n domain and I specify the port, which I set to 3002.
In that case, I can reach baserow using the n8n domain appending :3002, without SSL. The same is happening for portainer at :9443
v2.7.6
As I told before, I followed a guide from n8n documentation that helped me set up a docker stack with caddy and n8n. Here’s the guide for reference: Digital Ocean | n8n Docs
Docker
flush_interval -1
