Hi everyone, I’m using Caddy in production and now I have a customer that uses a response header that needs to be “sessionId”. Their application is case sensitive.
I realize that a direct request to the backend, will return: sessionId: a3688a2d-5b20-4d04
but when the request goes through Caddy, the capitalization changes to: Sessionid: a3688a2d-5b20-4d04
The definition of my Caddyfile for this backend is:
Is there any way to preserve or rewrite the response header before is sent to the origin?
I found a lot of information about why Headers should be case-insensitive. But I cannot make the customer change their application because the way they use that header from other backends.
HTTP headers are case-insensitive; relying on them being case-sensitive is a bug in their application. I know this isn’t what you want to hear, but…
The Go standard library standardizes header names. If their application needs case-sensitivity, it first needs to respect the standards and then it can transform the case to its liking after consuming the header.
It’s also worth mentioning is that with HTTP/2 all header names get converted to lower-case, so while header names are case-insensitive they will be lower cased when using HTTP/2 as a necessary step in the protocol (I assume you’re not using HTTP/2 due to it being on port 80, but if you do move to it then it’s something you would need to deal with anyway).
Just as in HTTP/1.x, header field names are strings of ASCII characters that are compared in a case-insensitive fashion. However, header field names MUST be converted to lowercase prior to their encoding in HTTP/2. A request or response containing uppercase header field names MUST be treated as malformed (Section 8.1.2.6).
