I have a dockerized laravel app which uses php8.3-fpm as base image, the app works when using nginx without ssl. Default laravel nginx conf provided in docs (Deployment | Laravel 11.x - The clean stack for Artisans and agents)
Now I want to use caddy for deployment
my Caddyfile
DOMAIN {
root * /var/www/html/public
php_fastcgi app:9000 {
index index.php
@try_files {
file {
try_files {path} {path}/ /index.php?{query}
rewrite @try_files {http.matchers.file.relative}
respond /.ht* 403
DOMAIN is getting replaced by CI/CD.
I can access https://DOMAIN, but I only receive “File not found.”, the 404 is shown in the logs of the php container. “GET /index.php” 404
My docker-compose file:
app:
build:
context: ./docker/php
- ./:/var/www/html
- APP_ENV=local
- APP_DEBUG=true
- DB_HOST=db
- DB_PORT=3306
- DB_DATABASE=${DB_DATABASE}
- DB_USERNAME=${DB_USERNAME}
- DB_PASSWORD=${DB_PASSWORD}
- laravel
queue:
build:
depends_on:
- db
- redis
- ./:/var/www/html
command:
- /bin/bash
- -c
- "php artisan horizon"
- laravel
web:
image: nginx:latest
- "8000:80"
- ./:/var/www/html
- ./docker/nginx/default.conf:/etc/nginx/conf.d/default.conf
depends_on:
- app
- laravel
image: caddy:latest
restart: always
depends_on:
- app
- db
- redis
- ./docker/Caddyfile:/etc/caddy/Caddyfile
- ./:/var/www/html
- caddy_data:/data
- caddy_config:/config
- laravel
db:
image: mariadb:11
- dbdata:/var/lib/mysql
MYSQL_ROOT_PASSWORD: '${DB_PASSWORD}'
MYSQL_ROOT_HOST: '%'
MYSQL_DATABASE: '${DB_DATABASE}'
MYSQL_USER: '${DB_USERNAME}'
MYSQL_PASSWORD: '${DB_PASSWORD}'
MYSQL_ALLOW_EMPTY_PASSWORD: 'yes'
- laravel
redis:
image: redis:latest
- laravel
laravel:
driver: bridge
dbdata:
caddy_data:
caddy_config:
{"level":"info","ts":1722434967.1232936,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:4: unrecognized directive: logs
{"level":"info","ts":1722434967.845685,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434968.472727,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434969.2899618,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434970.5444362,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434972.531269,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434976.2031136,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434983.0037699,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722434996.1406574,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722435022.066345,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'php_fastcgi': unrecognized subdirective param, at /etc/caddy/Caddyfile:10
{"level":"info","ts":1722435073.6095667,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722435133.9515722,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722435133.9529414,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1722435133.9529624,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1722435133.9539216,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1722435133.9542818,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1722435133.9543064,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1722435133.9546776,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x4000449b00"}
{"level":"info","ts":1722435133.954879,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1722435133.954928,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1722435133.954984,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1722435133.9550653,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1722435133.9550707,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["***"]}
{"level":"info","ts":1722435133.955816,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1722435133.9558358,"msg":"serving initial configuration"}
{"level":"info","ts":1722435133.9574745,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"4fe47fb6-74a7-4559-bfb6-624abfd89b5a","try_again":1722521533.9574728,"try_again_in":86399.9999996}
{"level":"info","ts":1722435133.9576988,"logger":"tls","msg":"finished cleaning storage units"}
Using docker-compoe
Docker on Ubuntu 22.04
Thank you for your help guys.
