Delete domain by @id
Caddy v2.2.1
sudo systemctl start caddy
ubuntu 18.04
  "http": {
    "servers": {
      "srv0": {
        "idle_timeout": "10s",
        "listen": [":443"],
        "read_header_timeout": "10s",
        "read_timeout": "10s",
        "routes": [
            "@id": "1-domain",
            "handle": [
                "handler": "subroute",
                "routes": [
                    "handle": [
                        "handler": "vars",
                        "root": "/path/to/frontend"
                    "handle": [
                        "handler": "reverse_proxy",
                        "upstreams": [
                            "dial": "unix//path/to/sockfile.sock"
                    "match": [
                        "not": [
                            "path": [
                              "/static*"
                    "handle": [
                        "handler": "file_server",
                        "hide": [
                          "/etc/caddy/Caddyfile"
            "match": [
                "host": [
                  "www.domain1.tdl"
            "terminal": true
            "@id": "2-domain",
            "handle": [
                "routes": [
                    "handle": [
                        "handler": "vars",
                        "root": "/path/to/frontend/"
                    "handle": [
                        "upstreams": [
                    "match": [
                        "not": [
                            "path": [
                              "/static*"
                    "handle": [
                        "hide": [
            "match": [
                "host": [
                  "www.domain2.tdl"
            "terminal": true
        "write_timeout": "10s"
i want to delete domain by id
i found delete like this but
curl -X DELETE curl http://localhost:2019/config/apps/http/servers/srv0/routes/1
can i delete like this?
curl -X DELETE curl http://localhost:2019/my__domain__id
Thank you
Hi,
i found solution.
thank you
"@id": "my__domain__id",
curl -X DELETE http://127.0.0.1:2019/id/my__domain__id
