Define ACME Servers locations for Certs request
I want to restrict incoming traffic to my network from the GeoIP white list in my firewall. As I have no requirements to allow incoming connections from USA, I want to block this country as well. (Current log analysis shows that most traffic to brute-force known vulnerabilities comes from CN, USA and ru)
My problem however is that Caddy is requesting new certificates from ACME servers and I am getting requests from USA ACME servers which do not work if I block USA incoming traffic.
Error message is clear, where ACME says that it can not reach my server thus could not issue cert.
v2.9.1
Debian, Proxmox, LXC container
/usr/bin/caddy run --environ --config /etc/caddy/Caddyfi
Type=notify
mysrv1 {
        reverse_proxy 192.168.x.x:pppp
mysrv2 {
mysrv3 {
                reverse_proxy 192.168.x.x:pppp {
                        header_down Strict-Transport-Security "max-age=15552000; includeSubDomains"
Check the documentation on configuring a different ACME provider, if you found one in a nation more to your preferences. Buypass, perhaps? Another alternative might be using DNS challenges which would let you to keep your Caddy server entirely inaccessible.
