Default route for dynamic endpoints
Hi,
I have a scenario with 2 different backends. 1 that has a fixed path for requests and the second one is dynamic. The endpoints are created dynamically. So I am trying to build a rule for “everything that doesn´t go to the first path” rule on Caddy.
Thanks much in advanced!
My Caddyfile
redir https://{host}{uri}
test.application.io:443 {
  gzip
  tls /root/.caddy/wildcard.application.com/bundle-ca.pem /root/.caddy/wildcard.application.com/key.pem
  log / stdout "{remote} - {user} [{when}] \"{method} {uri} {proto}\" {status} {size} {latency}"
  errors stderr
  timeouts 2h
  proxy /services backend1:8080 {
  proxy / backend2:8080 {    ##Here I need a default route
    policy round_robin
The setup you’ve got there looks good - everything for /services will go to backend one, and anything else will go to backend two. Are you running into any trouble with it?
