How can i change the default 404 page when the domain is not found?
I’m using multiple domain configurations but there doe not seem to be a place to add a default error page.
Hi @eddie,
You can designate a static HTML file to be served when a specific error status is issued.
Check out the errors
directive - one of the examples demonstrates custom error pages for 404s and 500s:
I know that but i have multiple domains.
so if i test with
errors {
404 /data/storage/serv/404.html
500 /data/storage/serv/500.html
example.com {
filemanager
it gives an error:
caddy.conf:2 - Error during parsing: Unknown directive ‘404’
But i already figured it out, you need to wrap it in 0.0.0.0, so it listens for all
0.0.0.0 {
errors {
example.com {
filemanager
I leave this here so someone else may find it usefull.
–edit: formatting
As per the Caddyfile documentation:
The first item of every Caddyfile must be the site name, and with multiple sites, you must open a brace block after the labels for that site. With your first test, Caddy thinks “errors” is the hostname of your website, and “404” / “500” are directives (which they aren’t, causing the error you received).
There’s also a few caveats to your last example:
- The default port is 2015, so a site listening on
0.0.0.0
should only respond if you browse to your server on that port. A better catch-all might be just:80 {errors ...}
. - Being a catch-all, and the fact that Caddy matches a single site, your custom error pages will only work if the site accessed is not
example.com
. That might be your intention, but it’s an important distinction for people who might want their custom error pages on all their sites. To do that, you’d have to put theerrors
directive once in each site block you have in your Caddyfile.
