Development version from git
Systemd unit provided by ubuntu package
Ubuntu 20.04
# domain name.
experimental_http3
email ******@linuxandria.com
admin off
output stdout
level debug
(cert) {
dns cloudflare *************
linuxandria.com {
redir https://www.linuxandria.com{uri} permanent
#test.linuxandria.com {
# import cert
# encode * gzip {
# gzip 9
# file_server
# php_fastcgi unix//run/php/php7.4-fpm.sock
# root * /var/www/test
# reverse_proxy * localhost:2369
# push
www.linuxandria.com {
import cert
encode gzip zstd
root * /var/www/html
push
xyzz4.linuxandria.com {
import cert
encode gzip zstd
root * /var/www/matomo
push
downloads.linuxandria.com {
import cert
encode gzip zstd
root * /var/www/downloads
push
jenkins.linuxandria.com {
import cert
encode gzip zstd
reverse_proxy 127.0.0.1:7070
git.linuxandria.com {
import cert
encode gzip zstd
reverse_proxy * localhost:8181 {
header_up X-Real-IP {http.request.remote.host}
header_up X-Forwarded-For {http.request.remote.host}
header_up X-Forwarded-Proto {http.request.scheme}
admin.linuxandria.com {
import cert
encode gzip zstd
reverse_proxy * localhost:9080
bw.linuxandria.com {
import cert
encode gzip zstd
header / {
X-Frame-Options "DENY"
X-Robots-Tag "none"
-Server
reverse_proxy /notifications/hub/negotiate 172.18.0.2:80
reverse_proxy /notifications/hub 172.18.0.2:3012
reverse_proxy 172.18.0.2:80 {
nc.linuxandria.com {
import cert
encode gzip zstd
root * /var/www/nextcloud
push
cdn.linuxandria.com {
import cert
root * /var/www/cdn
#zzyx5.linuxandria.com {
# import cert
# root * /var/www/bypass
# encode gzip
# file_server
Using the suggestions from the documentation, trying to turn on debug logs is crashing caddy.
N/A
What’s in the caddyfile
