): 2.4.1
a. System environment: Docker 20.10.7 on Ubuntu 18.04
docker-compose -f docker-compose.yml -f docker-compose.azurevm-highperf-caddy.yml up
docker-compose.yml
version: "2"
elasticsearch:
build:
context: elasticsearch/
- elasticsearch-data:/usr/share/elasticsearch/data
- ./elasticsearch/config/elasticsearch.yml:/usr/share/elasticsearch/config/elasticsearch.yml:ro
node.name: elasticsearch
cluster.initial_master_nodes: elasticsearch
ES_CLUSTER_NAME: search-cluster
ES_DATA_DIR: /usr/share/elasticsearch/data
- elk
elasticsearch-data:
driver: local
elk:
driver: bridge
version: "2"
elasticsearch:
restart: always
ES_JAVA_OPTS: "-Xmx4000m -Xms4000m"
image: caddy:2.4.1
restart: always
- ./caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- ./caddy-config:/config
- ./caddy-data:/data
- 443:443
- elk
depends_on:
- elasticsearch
acme_ca https://acme.zerossl.com/v2/DV90
email alex@skwar.me
admin off
{$DOMAIN}:443
encode zstd gzip
level INFO
output file /data/access.log {
roll_size 10MB
roll_keep 10
handle_path /elasticsearch* {
basicauth bcrypt Elasticsearch {
import elasticsearch.auth.*
reverse_proxy http://elasticsearch:9200
When I start the Docker containers, Caddy will create a file /config/autosave.json
. Is it important to keep this file? I’ll never access the admin interface; all config changes are done in the Caddyfile.
And what about the /data
directory? Do I need to make sure that the contents of this directory is saved? It contains the certificates; if the directory gets lost (because of a crash of the system or because the containers get run at a different system), Caddy would get new certificates, wouldn’t it?
