Custom storage plugin help
Hello! I’m trying to write a plugin that extends the default FileStorage module to use less restrictive permissions. My use case is that I want to access Caddy’s certificates from another (non-root) app.
There was a thread about this recently (Certificate file permissions when sharing certificates), and I’m hoping that someone can help me with the practicalities of it – I’m new to Go!
I have a starting point as follows. With some logging, I can see that CertMagicStorage() and Store() are both called, and the resulting permissions are correct. My problem is that the files written by Store() aren’t in the root directory as defined in my Caddyfile (they’re written to the directory from which I started xcaddy).
It’s unclear to me how this root path is handled in certmagic’s own filestorage module. Maybe someone with some more Go experience can shed some light?
Caddyfile:
  storage permissive_file_storage {
    root "/home/tao/.caddy"
  http_port 8080
  https_port 4443
localhost
Module code:
package permissivefilestorage
import (
	"io/ioutil"
	"log"
	"os"
	"path/filepath"
	"github.com/caddyserver/caddy/v2"
	"github.com/caddyserver/caddy/v2/modules/filestorage"
	"github.com/caddyserver/certmagic"
func init() {
	caddy.RegisterModule(PermissiveStorage{})
type CertmagicStorage struct {
	certmagic.FileStorage
	Path string
type PermissiveStorage struct {
	filestorage.FileStorage
func (PermissiveStorage) CaddyModule() caddy.ModuleInfo {
	return caddy.ModuleInfo{
		New: func() caddy.Module { return new(PermissiveStorage) },
// CertMagicStorage converts s to a certmagic.Storage instance.
func (s PermissiveStorage) CertMagicStorage() (certmagic.Storage, error) {
	// s.Root has the correct value from my Caddyfile
	return &CertmagicStorage{Path: s.Root}, nil
// Override Store to use globally-readable permissions
func (fs *CertmagicStorage) Store(key string, value []byte) error {
	filename := fs.Filename(key)
	err := os.MkdirAll(filepath.Dir(filename), 0755)
	if err != nil {
		return err
	return ioutil.WriteFile(filename, value, 0644)
I think I managed to work it out. In my custom certmagic.FileStorage struct, I had to initialize the Path field:
// <snip>
		FileStorage: certmagic.FileStorage{
			Path: s.Root,
	}, nil
Haven’t run this in production yet, but it seems to work.
