Custom Caddy Build with http.handlers.rate_limit — “a rate limit zone requires both a window and maximum events” error won’t go away
I’m new to Caddy setup and have been trying to use chatgpt to get rate limiting working so I can better protect against brute force etc.
I’m trying to apply Caddy v2.7+ rate_limit on login attempts only, not all traffic. I’ve used route blocks and matchers before. This config was working but was too aggressive — I’m now trying to scope it down to /login paths only.
However, now I get an error at startup that a rate limit zone requires both a window and events value. Even if I provide them, the same error appears. I am testing on a Windows 10 setup using a custom v2.7.6 Caddy binary with the http.handlers.rate_limit plugin.
A minimal example using route + rate_limit + matcher still fails.
2025/07/16 21:51:20.203 ←[34mINFO←[0m maxprocs: Leaving GOMAXPROCS=2: CPU quota undefined
2025/07/16 21:51:20.205 ←[34mINFO←[0m using config from file {“file”: “Caddyfile”}
Error: adapting config using caddyfile: parsing caddyfile tokens for ‘route’: parsing caddyfile tokens for ‘rate_limit’: a rate limit zone requires both a window and maximum events, at Caddyfile:13, at Caddyfile:28
shell
Copy
Edit
v2.7.6-custom (Windows build, includes http.handlers.rate_limit)
Windows 10 x64
Running from extracted folder (not service)
caddy run --config Caddyfile
N/A (manual run via CLI).
(sd.riftz.duckdns.org) {
	handle_path /login* {
		route {
			rate_limit loginzone {
				key {remote_host}
				window 30s
				events 5
			reverse_proxy 127.0.0.1:7860
sd.riftz.duckdns.org {
	import sd.riftz.duckdns.org
Your syntax is wrong. There should be a zone block nested inside rate-limit:
		route {
			rate_limit {
				zone loginzone {
					key {remote_host}
					window 30s
					events 5
See this linked section:
thank you for the quick response. I am very new to Caddy, can you let me know if what I am trying is possible. I have several sites that use caddy for auth but I have others that do not like audiobookshelf and such. I’ve been trying to find a way to get caddy to block or cool down the site access using rate limiting which works for caddy auth sites but not the others like audiobookshelf. Is this even possible somehow with caddy? I really just want to mitigate brute force and bots for my web apps
