1. Output of caddy version
v2.6.2
Caddy runs as a docker container on Ubuntu 22.02 virtualized host. The VM is installed on Proxmox running on a bare-metal NUC.
Host OS is Ubuntu 22.04.1 LTS
Docker is v20.10.12
FROM caddy:builder AS builder
RUN xcaddy build \
FROM caddy:latest
docker-compose up -d
version: '3.9'
cloudflared:
image: cloudflare/cloudflared:latest
container_name: cloudflared
net-proxy:
ipv4_address: 192.168.20.10
command: tunnel run
TUNNEL_TOKEN: ${TUNNEL_TOKEN}
net-proxy:
external: true
version: '3.9'
image: caddy:cloudflare
restart: always
net-proxy:
ipv4_address: 192.168.20.11
net-macvlan:
ipv4_address: 10.1.10.30
TZ: ${TZ}
PUID: ${PUID}
PGID: ${PGID}
CLOUDFLARE_EMAIL: ${CLOUDFLARE_EMAIL}
CLOUDFLARE_API_TOKEN: ${CLOUDFLARE_API_TOKEN}
- /var/log/caddy:/var/log/caddy
- ${DOCKER_APP_DIR}/caddy/Caddyfile:/etc/caddy/Caddyfile
- ${DOCKER_APP_DIR}/caddy/config:/config
- ${DOCKER_APP_DIR}/caddy/data:/data
net-proxy:
external: true
net-macvlan:
external: true
version: '3.9'
x-crowdsec-common: &crowdsec-common
restart: always
security_opt:
- no-new-privileges:true
x-crowdsec-environment: &crowdsec-environment
TZ: ${TZ}
crowdsec:
image: crowdsecurity/crowdsec:latest
container_name: crowdsec
<<: *crowdsec-common
net-proxy:
ipv4_address: 192.168.20.2
net-macvlan:
ipv4_address: 10.1.10.33
expose:
- "8080" # API
- "6060" # Metrics
<<: *crowdsec-environment
COLLECTIONS: ${COLLECTIONS}
CUSTOM_HOSTNAME: ${CUSTOM_HOSTNAME}
GID: ${GID}
- ${LOCALTIME_DIR}:/etc/localtime:ro
- ${HOST_LOGS}:/var/log:ro
- ${DOCKER_APP_DIR}/crowdsec/data:/var/lib/crowdsec/data
- ${DOCKER_APP_DIR}/crowdsec/config:/etc/crowdsec
cloudflare-bouncer:
image: crowdsecurity/cloudflare-bouncer:latest
container_name: cloudflare-bouncer
net-proxy:
ipv4_address: 192.168.20.3
- ${DOCKER_APP_DIR}/crowdsec/cloudflare-bouncer/config.yaml:/etc/crowdsec/bouncers/crowdsec-cloudflare-bouncer.yaml
net-proxy:
external: true
net-macvlan:
external: true
## Caddyfile
## Global Parameters
email [redacted]
## Snippets
(cloudflare) {
protocols tls1.3
(trusted) {
trusted_proxies \
173.245.48.0/20 \
103.21.244.0/22 \
103.22.200.0/22 \
103.31.4.0/22 \
141.101.64.0/18 \
108.162.192.0/18 \
190.93.240.0/20 \
188.114.96.0/20 \
197.234.240.0/22 \
198.41.128.0/17 \
162.158.0.0/15 \
104.16.0.0/13 \
104.24.0.0/14 \
172.64.0.0/13 \
131.0.72.0/22 \
10.0.0.0/8 \
172.16.0.0/12 \
192.168.0.0/16
## Reverse Proxy Hosts
mealie.ws.house {
import cloudflare
output file /var/log/caddy/mealie-access.log
reverse_proxy mealie:3000 {
import trusted
3. The problem Iβm having:
Iβve recently migrated to caddy after being a long-time NPM user. Iβve installed crowdsec as a docker container on the same network as caddy (network, net-proxy), and am having issues with crowdsec parsing my caddy access logs. Crowdsec has /var/log/caddy/*.log configured in acquis.yaml as type = caddy as shown below:
filenames:
- /var/log/caddy/*.log
labels:
type: caddy
All external traffic is routed through cloudflared tunnel β caddy β internal service. All access logs show βremote_ipβ as my local cloudflared (192.168.20.10), instead of the actual client. As a result, crowdsec sees 192.168.0.0/16 as βwhitelistedβ, and doesnβt yield any alerts. Below are logs from accessing https://mealie.ws.house from my personal device with an actual IP of 107.127.28.144.
Output of /var/log/caddy/mealie-access.log
{"level":"error","ts":1673185496.8189387,"logger":"http.log.access.log6","msg":"handled request","request":{"remote_ip":"192.168.20.10","remote_port":"43890","proto":"HTTP/2.0","method":"POST","host":"mealie.ws.house","uri":"/api/auth/token","headers":{"X-Forwarded-Proto":["https"],"Referer":["https://mealie.ws.house/login"],"Cookie":[],"Accept-Language":["en-US"],"Cf-Ipcountry":["US"],"Cf-Ray":["78655ee99e522275-MIA"],"X-Forwarded-For":["107.127.28.144"],"Cf-Connecting-Ip":["107.127.28.144"],"Content-Type":["multipart/form-data; boundary=----WebKitFormBoundary4Zw8j8KFpAv8Z2JE"],"Origin":["https://mealie.ws.house"],"Accept-Encoding":["gzip"],"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 16_2 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Mobile/15E148 Safari/604.1"],"Content-Length":["352"],"Cf-Warp-Tag-Id":["646dcab4-6371-4810-a227-98b5dfe2438a"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Accept":["application/json, text/plain, */*"],"Cdn-Loop":["cloudflare"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mealie.ws.house"}},"user_id":"","duration":0.173152772,"size":45,"status":401,"resp_headers":{"Vary":["Accept-Encoding"],"Server":["Caddy","Caddy","uvicorn"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Content-Encoding":["gzip"],"Content-Type":["application/json"],"Date":["Sun, 08 Jan 2023 13:44:55 GMT"]}}
If I exec into crowdsec and run:
cscli --file /var/log/caddy/mealie-access.log --type caddy --verbose
I get the following output:
line: {"level":"error","ts":1673185218.5674167,"logger":"http.log.access.log6","msg":"handled request","request":{"remote_ip":"192.168.20.10","remote_port":"38900","proto":"HTTP/2.0","method":"POST","host":"mealie.ws.house","uri":"/api/auth/token","headers":{"Cf-Connecting-Ip":["107.127.28.144"],"User-Agent":["Mozilla/5.0 (iPhone; CPU iPhone OS 16_2 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Mobile/15E148 Safari/604.1"],"Referer":["https://mealie.ws.house/login"],"Origin":["https://mealie.ws.house"],"Cf-Ray":["7865581eccdd67bd-MIA"],"Cdn-Loop":["cloudflare"],"Content-Length":["362"],"Accept-Encoding":["gzip"],"Accept-Language":["en-US"],"X-Forwarded-Proto":["https"],"Cf-Ipcountry":["US"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cf-Warp-Tag-Id":["646dcab4-6371-4810-a227-98b5dfe2438a"],"Content-Type":["multipart/form-data; boundary=----WebKitFormBoundaryKgU09JjZEFVn8iOL"],"X-Forwarded-For":["107.127.28.144"],"Cookie":[],"Accept":["application/json, text/plain, */*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mealie.ws.house"}},"user_id":"","duration":0.175207567,"size":45,"status":401,"resp_headers":{"Content-Encoding":["gzip"],"Content-Type":["application/json"],"Vary":["Accept-Encoding"],"Date":["Sun, 08 Jan 2023 13:40:17 GMT"],"Server":["Caddy","Caddy","uvicorn"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
β s00-raw
| β π΄ crowdsecurity/docker-logs
| β π’ crowdsecurity/non-syslog (first_parser)
| β π΄ crowdsecurity/syslog-logs
β s01-parse
| β π’ crowdsecurity/caddy-logs (+19 ~2)
| β update evt.Stage : s01-parse -> s02-enrich
| β create evt.Parsed.request : /api/auth/token
| β create evt.Parsed.tz : GMT
| β create evt.Parsed.year : 2023
| β create evt.Parsed.timestamp : Sun, 08 Jan 2023 13:40:17 GMT
| β create evt.Parsed.day : Sun
| β create evt.Parsed.http_user_agent : Mozilla/5.0 (iPhone; CPU iPhone OS 16_2 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Mobile/15E148 Safari/604.1
| β create evt.Parsed.month : Jan
| β create evt.Parsed.monthday : 08
| β create evt.Parsed.remote_ip : 192.168.20.10
| β create evt.Parsed.time : 13:40:17
| β create evt.Parsed.verb : POST
| β update evt.StrTime : -> Sun Jan 08 13:40:17.000000 2023
| β create evt.Meta.log_type : http_access-log
| β create evt.Meta.target_fqdn : mealie.ws.house
| β create evt.Meta.http_path : /api/auth/token
| β create evt.Meta.http_status : 401
| β create evt.Meta.http_user_agent : Mozilla/5.0 (iPhone; CPU iPhone OS 16_2 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Mobile/15E148 Safari/604.1
| β create evt.Meta.http_verb : POST
| β create evt.Meta.service : http
| β create evt.Meta.source_ip : 192.168.20.10
β s02-enrich
| β π’ crowdsecurity/dateparse-enrich (+2 ~3 [whitelisted])
| β update evt.Whitelisted : %!s(bool=false) -> true
| β update evt.WhitelistReason : -> My IP Ranges
| β create evt.Enriched.MarshaledTime : 2023-01-08T13:40:17Z
| β update evt.MarshaledTime : -> 2023-01-08T13:40:17Z
| β create evt.Meta.timestamp : 2023-01-08T13:40:17Z
| β π’ crowdsecurity/geoip-enrich (+9)
| β create evt.Enriched.ASNumber : 0
| β create evt.Enriched.IsInEU : false
| β create evt.Enriched.IsoCode :
| β create evt.Enriched.Latitude : 0.000000
| β create evt.Enriched.Longitude : 0.000000
| β create evt.Enriched.ASNNumber : 0
| β create evt.Enriched.ASNOrg :
| β create evt.Meta.ASNNumber : 0
| β create evt.Meta.IsInEU : false
| β π’ crowdsecurity/http-logs (+7)
| β create evt.Parsed.file_frag : token
| β create evt.Parsed.file_name : token
| β create evt.Parsed.impact_completion : true
| β create evt.Parsed.file_dir : /api/auth/
| β create evt.Parsed.file_ext :
| β create evt.Parsed.static_ressource : false
| β create evt.Meta.http_args_len : 0
| β π’ crowdsecurity/whitelists (~1)
| β update evt.WhitelistReason : My IP Ranges -> private ipv4/ipv6 ip/ranges
β-------- parser failure π΄
Note, create evt.Parsed.remote_ip and create evt.Meta.source_ip both show my cloudflared local IP of 192.168.20.10. Within crowdsec config.yaml, Iβve set use_forwarded_for_headers: true as described here, but it made no difference.
Is there something I can change in my Caddyfile to make remote_ip reflect the correct X-Forwarded-For client IP, or should I pursue ip_mask for remote_ip to strip from the logs? Thank you for the assistance.
